Go to Post Now Dave, before you get all snarly about these- remember, I still have the button maker... - MissInformation [more]
Unread 04-02-2015, 00:51
kylelanman's Avatar
kylelanman kylelanman is offline
Programming Mentor
AKA: Kyle
FRC #2481 (Roboteers)
kylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to all
Re: roboRIO Command Based Problems
 48void DriveBase::AutoDriveTurn(float speed, float angle){
 49         while(drive_gyro->GetAngle() >= angle){
 50                 fl_motor->Set(speed);
 51                 fr_motor->Set(speed);
 52                 bl_motor->Set(speed);
 53                 br_motor->Set(speed);
 54         }
 55 }
This function is going to cause you problems. This is called a "tight loop" and will consume all of your CPU power while blocking your main thread. Because there is no delay the CPU is going to execute the loop as fast as it possibly can. It will likely take the CPU to 100% and then start dropping control packets from the driver station. On top of that while you are in the loop none of your other commands or code in the main thread will be running.
The better way to do this that won't cause you problems is to use a command.
 32 class AutoDriveTurnCommand() {
 33 private:
 34     double mSpeed;
 35     double mAngle;
 36 public:
 37     AutoDriveTurnCommand(double speed, double angle) {
 38         mSpeed = speed;
 39         mAngle = angle;
 40     }
 41     void Initialize() {
 42         Robot::drivebase->DriveTank(speed, speed);
 43     }
 44     void Execute() {}
 45     bool IsFinished() {
 46         return Robot::drivebase->GetGyroAngle() < mAngle;
 47     }
 48     void End() {
 49         Robot::drivebase->DriveTank(0, 0);
 50     }
 51     void Interrupted() {
 52         End();
 53     }
 54 };
For this to work you will need to define a function in DriveBase called GetGyroAngle that returns the angle of the gyro.
"May the coms be with you"
Is this a "programming error" or a "programmer error"?
Unread 04-02-2015, 00:57
King Nerd III's Avatar
King Nerd III King Nerd III is offline
Chief Programmer/Head of Autonomous
AKA: Isaac
FRC #1410 (The Kraken)
King Nerd III is an unknown quantity at this point
Originally Posted by kylelanman View Post
 54         }
 55 }
 33 private:
 34     double mSpeed;
 35     double mAngle;
 36 public:
 38         mSpeed = speed;
 39         mAngle = angle;
 40     }
 43     }
 47     }
 48     void End() {
 50     }
 52         End();
 53     }
 54 };
Thanks for the tip, but that couldn't be what's causing the error with not updating fast enough. That method isn't even called in the code yet, plus ita autonomous and we only get the error in teleop. Thanks for the tip, though! I'll probably use that!
Unread 10-12-2015, 15:22
AKA: Isaac
I know this is an old thread, and I'm replying to myself, but yesterday we figured out the problem. In the Robot.cpp we were calling auto_command->End(); in the TeleOpInit Phase, but we had not given a specific command to auto_command, so when TeleOp was enabled it couldn't end the command and just died... At least that's how I believe we fixed it. Commenting out the auto_command->End() got rid of this problem, so we believe that's what it was.
Hope this helps!
Isaac
Isaac
Chief of Programming and Head of Autonomous Control
FRC Team 1410
