Go to Post We might just dip the entire bot in a Locktite bath before bagging. - Kevin Ray [more]
Unread 04-02-2015, 01:05
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
Re: Eclipse is being a butt
Originally Posted by King Nerd III View Post
The very fact that eclipse doesn't clear out old errors and I have to manually delete them for my program to compile correctly raises many red flags for me. Visual Studio has worked perfectly for me, and I've never had as terrible of a problem as it throwing ghosts errors at me, like eclipse, for example the other day I had the line:
double speed = 0.5;
and got and error that said (not exact quote) "incompatible types, int to double"
My point is, Eclipse hasn't been stable at all for me, and I would rather have a tool I know works and trust (Visual Studio) than a tool that has not worked so far. I can't even import a project into a workspace, for crying out loud!
The errors are coming from the compiler, not from Eclipse. Eclipse is just an application framework. With respect, I think you need to read the manuals and more carefully follow the install instructions or you are never going to finish. This environment and cross development in general is more complex than simple VS projects. FYI - I import projects into Eclipse and export projects out of Eclipse every day. Many of the things you say are simply not the case. Our team has had 5 different students install and use Eclipse without problems and I'm developing under Linux. I'm not an Eclipse lover (hate the editor) but it is working as advertised.
