Go to Post I saw a big opening in the bees section and asked if we could sit for this match and was told we were welcome to sit there. Your team made space for about 15 of my team members that came with me. - Debbie [more]
Go Back   Chief Delphi > Technical > Robotics Education and Curriculum
Unread 04-02-2015, 08:01
matthewdenny's Avatar
matthewdenny matthewdenny is offline
FRC #6054 (Dukes)
matthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant future
VEX controllers & Servos Voltage question
We have both some VEX controllers (Cortex) as well as standard futaba (5V servos). We would like to use them together.
The issue is that I think the motor ports on the Vex controller have 7.2 V outputs. I think this because all the VEX COTS motors are rated at 7.2V. This seems too high for a standard servo. I was considering using a L7805 voltage regulator on the power pin of the VEX output, I am also wondering if I would need a voltage regulator on the signal/PWM pin from the Cortex as well, or if it would be okay to leave as is.
Unread 04-02-2015, 08:47
gpetilli gpetilli is offline
FRC #1559
gpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to all
Re: VEX controllers & Servos Voltage question
Do you plan on using the VEX controller on a 2015 FRC robot? I don't believe the controller is legal per rule R41. The servo is probably okay per rule R18 assuming it has a max power of 4W. Can you connect the servo directly to the PWM outputs of the roboRIO? I believe they are already setup for 5V.
Unread 04-02-2015, 09:11
FRC #6054 (Dukes)
This is completely unrelated to FRC robotics. I am a teacher and just trying to maximize the teaching supplies in my room by making the two things compatible with each other.
