Go to Post ...regardless of anything that happens, there should be no booing at competitions, only cheers. True, many of us want to win, but in the end, all of us are working to expand FIRST and to promote the inspiration and recognition of science and technology through gracious professionalism. - Aignam [more]
Unread 04-02-2015, 12:15
Richard Wallace's Avatar
Richard Wallace Richard Wallace is online now
I live for the details.
FRC #3620 (Average Joes)
Re: Help Calculating time to recharge air tanks
Originally Posted by Jon Stratis View Post
I'm no expert, but I've been repeating the "conventional wisdom" for years as an inspector and making teams replace their spike fuse with a breaker for the compressor. I had heard that the fuse will wear out over time due to the start up surge until it eventually pops...
Can anyone with a better understanding correlate the readings posted in this thread with the compressor breaker rule we've all been following for years?
I am not an expert, but my team has made some tests which may shed some light. See attached summary of our set up and results for recharging a 48 cubic inch system using three FRC-legal compressors.
When recharging from ~100 to ~120 PSI, the compressor must start against load. As Mr. V pointed out above, this case is much more pertinent to actual FRC operation than the tests I reported earlier.
The initial peak surge current observed using Viair compressors is relatively short duration (<0.1 sec), but the Thomas compressor's initial peak surge current is much longer duration (~0.5 sec). Comparing the Thomas surge against typical automotive fuse curves suggests an explanation for the "conventional wisdom" Jon mentioned above. The Thomas compressor has much less margin against blowing a 20A fuse during surge, and historically that is the compressor on which our FRC "conventional wisdom" is based.
Richard Wallace
since 2003
Unread 05-02-2015, 00:57
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
Excelent and very useful data, thanks very much.
What people need to keep in mind is that a fuse and the type of circuit breakers that we use are thermal devices. When they reach a certain temp they will open. With a large overload it will open almost instantaneously. With a slight overload it will open but in a longer period. With intermittent medium overloads it can eventual heat to the point where it opens.
So the old Thomas compressor if it starts multiple times during a match could certainly eventually heat up the fuse to the point it opens. I'm not sure why they choose the ATM form factor instead of the ATO/ATC form factor as used for the 20/30 amp circuits on the PDP, PDB and Spike. The ATM is not that much smaller than the ATO/ATC.
Unread 20-02-2015, 05:33
yara92's Avatar
yara92 yara92 is offline
M.Fawdah Mechanical engineering
AKA: Mohamed
FRC #1946 (Mechka Monster)
Team Role: RoboCoach
yara92 will become famous soon enoughyara92 will become famous soon enough
Richard HI
I try the test. noting move may be because of the spike, I use defrent spike , nothing move.
TEAM 1946-Tamra
Unread 20-02-2015, 05:58
Originally Posted by yara92 View Post
Richard HI
I saw your questions in the other thread. Have you been able to determine if your Thomas compressor is still functioning normally? Do you have another compressor to try?
Richard Wallace
since 2003
Unread 20-02-2015, 13:14
yara92's Avatar
AKA: Mohamed
YesI have ,
for testing Iconnect dirict itis working.
My quation i you knowhow to use the spike as relay. I use Jumber, the output 0 [V]
TEAM 1946-Tamra
Unread 20-02-2015, 14:40
YesI have ,
Ok, now I understand your question. I caused confusion by showing the control connection between the pressure switch and the Spike incorrectly in the diagram attached in my earlier post. The connection used on my team's bench test board is shown in the attached (revA) version of that diagram.
Richard Wallace
since 2003
