Go to Post *sigh* Anything else we can do to get this thing to work? - domoarigato [more]
Unread 29-01-2015, 21:10
RichardNixon's Avatar
RichardNixon RichardNixon is offline
FRC #2220
RichardNixon is an unknown quantity at this point
Mecanum gearbox issues
We have been having issues with our mecanum wheels turning at different speeds. We think it might be a gearbox issue but we couldn't find anything. It could be a sim motor issue. We have narrowed it down to the gearbox/sim area. Any thoughts on potential issues with mecanum drives?
Unread 29-01-2015, 21:13
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
Re: Mecanum gearbox issues
Can you clarify what gearboxes you are using? Also, if you turn the wheels by hand with the robot powered off, are certain wheels harder to turn than others?
Unread 29-01-2015, 21:30
Chris_Ely's Avatar
Chris_Ely Chris_Ely is offline
AKA: luckof13
FRC #3414 (HackBots)
Chris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond repute
Are your motor controllers calibrated? This is the most likely cause for motors turning different speeds. What motor controllers are you using?
*Also; CIM, not "sim".
2013: Waterford Finalist, Livonia Winner, MSC Quarterfinalist, Curie Division
2012: Waterford, Northville, Livonia
2011: Waterford Finalist, Livonia
2010: Ann Arbor Rookie Inspiration Award, Troy
Mechanical Engineering Student,
Michigan Technological University
Unread 30-01-2015, 09:09
efoote868 efoote868 is online now
foote stepped in
AKA: E. Foote
FRC #0868
This is a common issue, which is why teams will use encoder feedback to vary motor outputs in a control loop, to get each wheel turning at the desired speed set point.
Be Healthy. Never Stop Learning. Say It Like It Is. Own It.
Like our values? Flexware Innovation is looking for Automation Engineers. Check us out!
Unread 30-01-2015, 09:12
Nick Lawrence's Avatar
Nick Lawrence Nick Lawrence is offline
Commander Canada
FRC #3940 (CyberTooth, AndyMark)
Nick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond repute
It could also be a center of gravity issue. If you don't have encoder feedback on each of the wheels, and the COG is not centered between the wheels in the X and Y direction, the robot may not drive straight or strafe straight as desired.
-Nick
Alumnus of 1503 Spartonics
Founding Mentor of 5406 Celt-X
Mechanical Design Mentor of 3940 CyberTooth
Emceeing events since 2013 - come say hi!
Success doesn't always equate to match wins. It's about the wins off the field.
Unread 30-01-2015, 16:16
FRC #2220
we are using vexpro single reduction gearboxes and there is a noticeable difference between the wheels when spun by hand.
Unread 30-01-2015, 16:26
GeeTwo's Avatar
GeeTwo GeeTwo is online now
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
The difference when spun by hand is the first place to look. There is apparently unequal drag (friction) among the wheels, which would definitely cause the unequal output speeds, especially at low speeds where the drag is a larger fraction of the total output of the motors. Check for misalignment in the various shafts, bearings, and gears. If you are unable to completely remove these differences and don't have enough time, energy, or expertise for encoders, you will probably want to find settings for each wheel which produces the same output speed when on blocks and driving slowly. Then add the differences in those amplitudes to the ones which require extra voltage. For example, if the four wheels require 10%, 8%, 7%, and 6% to make the same low speed, always add 4% to the amplitude of the first, 2% to the second, and 1% to the third. When driving the wheels backward, you will actually need to subtract these percentages to increase the amplitudes.
Unread 30-01-2015, 16:35
foote stepped in
AKA: E. Foote
FRC #0868
What motors / how many are you using per gearbox?
Unread 04-02-2015, 12:43
Snowfire Snowfire is offline
Team 2410 Frame/Drivetrain Team
FRC #2410 (Metal Mustangs)
Snowfire is an unknown quantity at this point
We had that issue. It's probably is that you need to calibrate your motor controllers or the pinion gears/other gears are different teeth. VEXpro's 12 tooth and 13 tooth pinion gave the same pitch distance, so you might have a mix
Team 2410
Mechanical, Electrical, Pneumatic, and Drivetrain
Unread 04-02-2015, 12:46
Andrew Lawrence
Posts: n/a
Correction: The 11T and 12T pinions have the same diameter (.7"OD), and the 13T and 14T pinions share the same diameter as well (.8" OD).
Unread 04-02-2015, 12:56
Mark Sheridan's Avatar
Mark Sheridan Mark Sheridan is offline
Head Mentor
FRC #3476 (Code Orange)
Mark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond repute
Its actually better to get gyro feedback. You don't need encoder feedback unless it auto. A control loop on each wheel is possible but overkill. The WPI library code for mecanum has a gyro input. the library code is very good, I have lost a wheel before and the robot still drove reasonably well.
RichardNixon, is the speed difference something you noticed driving on a bench or is your robot having trouble driving on the ground. Is it having trouble going straight? Is it rotating too much when your translating?
Team 3476| Mentor| 2014 - Current
Team 3309| Mentor| 2011 - 2016
Team 766 | Mentor| 2006 - 2011 | Alumnus | 2002-2005
Unread 04-02-2015, 16:40
Thank you!
Team 2410
Unread 04-02-2015, 22:35
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Encoders in teleop are still pretty useful if you can do it correctly. They make our movements much sharper.
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 05-02-2015, 03:02
Head Mentor
In my experience, having tried PD control on mecanum, having the gyro was much more important. I agree that you could get a good control loop on each wheel but I never felt it was a must have feature. I actually got rid of it because I felt it was overkill because it consumed a large amount of resources for a small gain.
You and me probably seen our fair of mecanum drives with no gyros or encoders. To me the gyro is a must have feature for mecanums to operate effectively. I seen so many team struggle with mecanum because they did not realize the importance of using a gyro. Hopefully OP comments more but I am speculating its a control issue.
