Go to Post What is this, presto change-o rules every week? - Racer26 [more]
Unread 04-02-2015, 15:53
wolverines wolverines is offline
FRC #5596
wolverines is an unknown quantity at this point
Re: Problem Downloading Code to Robot
Hello,
I also have the same problem with my computer. I can download code to the RoboRio inky from my classmate computer that was given to me by FRC. When I try any other computer I am unable to connect to the Rio. I have tried many different ways of solving this problem but none have worked. Please HELP!
Unread 05-02-2015, 09:04
nickmcski nickmcski is offline
AKA: Nicholas McCurry
FRC #1482 (Grandin Ghosts)
nickmcski has a spectacular aura aboutnickmcski has a spectacular aura aboutnickmcski has a spectacular aura about
Originally Posted by wolverines View Post
Hello,
Can you post your error message here when you compile, anthonygraff24's error is because he doesn't have the correct java installed so his computer cant compile to the code. But the process of compiling and sending the code to the robot can be very complex and has a lot of failure points, without your exact error message it will be really to pinpoint your exact problem.
