Go to Post Its just going to be a dirt game. We are going to be using shovel bots to dig for gold. Anyone who strikes oil gets the 100 point bonus! - Uberbots [more]
Unread 02-02-2015, 13:57
ironmare ironmare is offline
FRC #5072
ironmare is an unknown quantity at this point
Mecanum wheels spinning too fast!
Before and after we have programmed a "dead zone" into our coding, we noticed that our xbox 360 thumbsticks are very touchy. Just barely moving the joysticks move the robot wheels too fast. What I need is some Labview coding that slowly starts moving the robot in the direction the thumbstick is being pushed, and then it ramps up to a higher speed when the the thumbstick is pushed all the way. Any help?
Unread 02-02-2015, 14:02
pastelpony's Avatar
pastelpony pastelpony is offline
Programmer/Electrical
AKA: Zach M
FRC #3525 (Nuts and Bolts of Fury)
pastelpony will become famous soon enough
Re: Mecanum wheels spinning too fast!
I would try to put in a selector that would take the input from the joystick and halve (or divide) it until it is greater or equal to 1 and then keep it constant to increase speed. Add in your deadzone and this should work.
Team 3525 Head Programmer (2014- ) - Java (Formerly LabVIEW)
Unread 02-02-2015, 14:04
Alpha Beta's Avatar
Alpha Beta Alpha Beta is offline
Strategy, Scouting, and LabVIEW
AKA: Mr. Aaron Bailey
FRC #1986 (Team Titanium)
Alpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond repute
Square or cube the joystick commands.
Regional Wins: 2016(KC), 2015(St. Louis, Queen City), 2014(Central Illinois, KC), 2013(Hub City, KC, Oklahoma City), 2012(KC, St. Louis), 2011(Colorado), 2010(North Star)
Regional Chairman's Award: 2014(Central Illinois), 2009(10,000 Lakes)
Engineering Inspiration: 2016(Smoky Mountain), 2012(Kansas City), 2011(Denver)
Dean's List Finalist 2016(Jacob S), 2014(Cameron L), 2013(Jay U), 2012(Laura S), 2011(Dominic A), 2010(Collin R)
Woodie Flowers Finalist 2013 (Aaron Bailey)
Championships: Sub-Division Champion (2016), Finalist (2013, 2010), Semifinalist (2014), Quaterfinalist (2015, 2012, 2011)
Other Official Awards: Gracious Professionalism (2013) Entrepreneurship (2013), Quality (2015, 2015, 2013), Engineering Excellence (Champs 2013, 2012), Website (2011), Industrial Design (Archimedes/Tesla 2016, 2016, 2015, Newton 2014, 2013, 2011), Innovation in Control (2014, Champs 2010, 2010, 2008, 2008), Imagery (2009), Regional Finalist (2016, 2015, 2008)
Unread 02-02-2015, 14:10
FRC #5072
How can I square or cube those joystick values, Alpha Beta? Also, pastelpony, would like to see that selector coding, thank you for your help!
Unread 02-02-2015, 14:34
samfruth's Avatar
samfruth samfruth is offline
FRC #1710 (Ravonics Revolution)
Team Role: Driver
samfruth will become famous soon enough
Can you give us a glimpse of what your code looks like right now?
Unread 02-02-2015, 14:46
The easiest way to square the joystick input values is to set the "square inputs" terminal to TRUE when you open your drive motors and let the WPI library take care of it for you.
If you want to cube them, then take the value from each joystick axis and multiply it by itself, then multiply the result by the original value.
Unread 02-02-2015, 14:53
pastelpony's Avatar
AKA: Zach M
Edited in.
Alpha Beta's Avatar
Squaring the inputs is a selectable feature built into the arcade and tank drive vi's. If you open one of them up you can see how it is done and mirror the logic. At first glance I didn't see it being utilized in the mecanum drive vi. I wonder if there is a reason.
Note there is a small bit of logic needed to restore the sign to values that were initially negative.
Name:	Square Inputs.PNG
Unread 02-02-2015, 15:10
pastelpony's Avatar
AKA: Zach M
Wouldn't squaring/cubing/multiplying the value of the inputs only make the stick more sensitive, though?
Unread 02-02-2015, 15:27
see attachment
Name:	squared and cubed.png
Unread 02-02-2015, 15:30
pastelpony's Avatar
AKA: Zach M
What is the value of (0.5)2 ?
I completely forgot that we're talking about decimals. Thank you for that reminder.
Unread 03-02-2015, 11:49
Bpk9p4's Avatar
Bpk9p4 Bpk9p4 is online now
FRC #1756
Bpk9p4 is infamous around these parts
they way we fit this is we create a lookup table and we run the joystick command through that. This way you can have a custom joystick response. This also allows you to add a deadband, back lash corrections and ramp rates
Unread 03-02-2015, 12:18
You seem to be implying that using a lookup table to shape the joystick output allows implementing a ramp rate, whereas using a function to shape the joystick output does not. Is that what you intended?
Unread 03-02-2015, 13:40
Bpk9p4's Avatar
FRC #1756
sorry no both ways work just as well. Just was putting out another option. We have just had good luck with this method. here is an example of how we use it http://i.imgur.com/Bq7QMuE.png
Unread 04-02-2015, 15:57
You mentioned you were using a Lookup Table for that.
Just for fun, when you have a symmetric piecewise linear curve like that with so few pieces, you can create a very simple tunable piecewise linear function.
I labeled the points (a,0), (a,b), and (c,d) on your diagram (attached).
C code for the piecewise linear code for that is quite simple:
// do the following once at initialization,
// or any time you change a ,b, c, or d on-the-fly:
m1=(d-b)/(c-a);  m2=(1-d)/(1-c);
// Let J be the abscissa and K be the ordinate on your graph.
// Here's the piecewise linear code to convert J to K:
x=fabs(J);
if (x<a) K=0;
else if (x<c) K=b+m1*(x-a);
else K=d+m2*(x-c);
if (J<0) K=-K;
