Go to Post Hype levels are reaching critical levels... - wjd13 [more]
Unread 04-02-2015, 16:09
mattoreo310 mattoreo310 is offline
FRC #4012
mattoreo310 is an unknown quantity at this point
Code Won't Deploy
Hello,
When I deploy the code to the Roborio I get this message.
Buildfile: C:\Users\Robouser\workspace\2015\build.xml
Trying to override old definition of task classloader
get-target-ip:
[echo] Trying Target: roboRIO-4012.local
[echo] roboRIO found via mDNS
dependencies:
[echo] roboRIO image version validated
deploy:
[sshexec] Connecting to roboRIO-4012.local:22
[sshexec] cmd : rm /home/lvuser/FRCUserProgram
[sshexec] rm: can't remove '/home/lvuser/FRCUserProgram': No such file or directory
[sshexec] Remote command failed with exit status 1
[echo] [athena-deploy] Copying code over.
[scp] Connecting to roboRIO-4012.local:22
BUILD FAILED
C:\Users\Robouser\wpilib\cpp\current\ant\build.xml :66: com.jcraft.jsch.JSchException: Could not send 'C:\Users\Robouser\workspace\2015\Debug\FRCUserPro gram' to '/home/lvuser' - 4: java.io.FileNotFoundException: C:\Users\Robouser\workspace\2015\Debug\FRCUserProg ram (The system cannot find the file specified)
Total time: 3 seconds
Unread 04-02-2015, 16:46
bob.wolff68's Avatar
bob.wolff68 bob.wolff68 is offline
Da' Mentor Man
FRC #1967
bob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nice
Re: Code Won't Deploy
At first glance it would seem that for some reason possibly your /home/lvuser directory on the roboRIO is inaccessible or other. I'd suggest re-image the roboRIO using the imaging tool. Something is suspicious here and this might resolve it.
If that fails and you're wanting to toubleshoot...if you are familiar with ssh and have a ssh client, could you ssh to the roborio and take a look?
ssh lvuser@roboRIO-4012.local:22
If this works, you should be sitting at a shell prompt. Do a:
ls -la /home
and
ls -la /home/lvuser
Let us know what the output of these commands are. That might prove useful in troubleshooting.
bob
Bob Wolff - Software from the old-school
Mentor / C / C++ guy
Team 1967 - The Janksters - San Jose, CA
Unread 04-02-2015, 17:17
FRC #4012
I re-imaged the roborio but i was told the frc error parsers were deleted. Could this be why the code won't load.
Unread 04-02-2015, 17:25
Da' Mentor Man
FRC #1967
I've never heard mention of 'FRC parsers' so I can't be sure. Are you saying that during the re-imaging process, the imaging tool noted to you that the FRC parsers were deleted? Or someone else told you that the FRC parsers were deleted?
bob
Unread 04-02-2015, 17:28
FRC #4012
The error parsers in eclipse.
Unread 04-02-2015, 17:44
Da' Mentor Man
FRC #1967
That starts to sound like an Eclipse plug-in problem to me.
Right-click on a project (left hand pane) and select 'Clean Project'
Are you able to compile code?
After compiling, on the project-pane, use the little 'triangle' to open up the 'Debug' folder ... is there a FRCUserProgram?
If so, you're able to compile for sure...that's basic toolchain validation.
Plugin - I'd suggest going back through the plugin installation on screensteps. In fact, I wonder if your auto-update might be turned off. Check the Eclipse preferences (Window->preferences in Windows) and look under 'Install/Update' - open that one up and select 'Automatic Updates' and make sure the 'Automatically find new updates and notify me' is selected. If not, select this, select 'ok' and then restart Eclipse to allow it an opportunity to check for updates. I think you can also trigger this by doing Help->CheckForUpdates.
If you're familiar with the command line, I'd still suggest the troubleshooting steps I mentioned about using ssh to look at the roboRIO directly.
Thanks,
bob
