Re: Talon SRX "speed_control" mode? (Python)
What's happening (symptoms) vs what are your expectations (what you expect to see).
I mean does the motor move? Talon SRX LEDs? Does the Talon show up in the web-based config? What mode is reported in the Self-Test after you enable? Is the sensor pos changing in the Self-Test? Is the sensor pos moving int a positive direction when positive throttle is applied? |
