Go to Post “There are two ways to compete, one is to drag your opponent down, the other is to raise the bar and excel. Which do you think is more beneficial to you in the long run?” -- John Abele - Candice.E [more]
Unread 04-02-2015, 19:55
Sparky910 Sparky910 is offline
FRC #0910
Sparky910 is an unknown quantity at this point
Anyone play with that AM Thrift Throttle at all?
Hey CD, I've been trying to get this Andy Mark "Thrifty Throttle" operational for our team to test with. From what I've read here using it on a speed controller is pretty straight forward and not too worried about that part. However, our team is looking to test with servos. I've tried externally powering a few servos while using the thrifty throttle, but to no avail. Has anyone gotten this working with servos? If so, how?
Thanks everyone!
Unread 04-02-2015, 21:00
2130driven 2130driven is offline
AKA: Michael Jolley
FRC #2130 (alpha+)
Team Role: Driver
2130driven is an unknown quantity at this point
Unhappy Re: Anyone play with that AM Thrift Throttle at all?
no clue
Unread 04-02-2015, 21:37
Jared's Avatar
Jared Jared is offline
From the user manual you linked:
NOTE: This unit produces a PWM signal only; it does not supply power to
devices. Devices such as servos, speed controllers etc. need a separate power
supply.
What sort of power supply are you using to power the servos? It should be 5-6 V.
Unread 05-02-2015, 13:39
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
Did you connect the ground of the power supply for the servo to the ground of the Thrift Throttle. The control signal to the servo needs a common reference to the power for the servo. Is your servo power adequate? They can draw a bit of current.
Brian K
Team 1225 Robotics Mentor
Unread 05-02-2015, 15:12
billbo911's Avatar
billbo911 billbo911 is online now
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Thanks everyone!
The little note at the bottom of the document you linked to says:
"NOTE: This unit produces a PWM signal only; it does not supply power to
supply"
No power on the middle pin to power the servo. There's you problem right there.
Unread 09-02-2015, 20:56
FRC #0910
Hey, here's what I tried the other week and all I got was some strange jittering from servos.
SuperBK, according to your post, is all I need to do is use configuration 2 on my image and connect ground in there?
Unread 09-02-2015, 22:57
slao slao is offline
AKA: Steven Lao
FRC #3161 (Tronic Titans)
slao has much to be proud ofslao has much to be proud ofslao has much to be proud ofslao has much to be proud ofslao has much to be proud ofslao has much to be proud ofslao has much to be proud ofslao has much to be proud of
Which servo is it? Some servos may require 6V to operate.
