Go to Post Boy you guys try to make my job harder every year. - Al Skierkiewicz [more]
Unread 05-02-2015, 09:34
Kyorox's Avatar
Kyorox Kyorox is offline
The Empty Headed Know-It-all
AKA: Jarod Lawther
FRC #4929 (Maroon Monsoon)
Kyorox is an unknown quantity at this point
Re: Really underhanded
Originally Posted by notmattlythgoe View Post
Make sure to calibrate the talons. To do this you press and hold the calibrate button on the talon until it starts to flash multiple colors. Then drive the motor full forward and full reverse a couple of times. Then let the button go. Do this for each Talon and this should even them out a bit for you.
This wont be exact thought correct? It will get them a lot closer though?
