Go to Post Y'know... I think I'd much rather have big balls than hang myself... - FotoPlasma [more]
Unread 05-02-2015, 00:09
FRC Team CC FRC Team CC is offline
FRC #6560 (Charging Champions)
FRC Team CC is an unknown quantity at this point
[FTC]: DC Controller Not Working
Dear Chief Delphi,
We are the Charging Champions, FTC Team 8660 from SoCal. Today when we were testing our robot, our DC Controller suddenly stopped giving power to its motors. All of the other controllers work and they are all receiving power (as the red lights on the controllers are on). However, in both tele-op and autonomous, the motors aren't receiving power from the controller that isn't working.
What could be the problem? Is there a solution, and if so, what is it?
All help is greatly appreciated.
Regards,
Charging Champions
FTC Team 8660
Unread 05-02-2015, 00:23
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
Re: [FTC]: DC Controller Not Working
Sounds like you might have blown the controller.
Have you checked the output of the motor controller with a multimeter?
Do the servos on your robot still work?
Look at your NXT screen, while in teleop, does the screen say "EXT Battery: OFF" (or something similar?).
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
2017 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 05-02-2015, 00:25
We do not have any servos on our robot: just DC's. The program does not say EXT BATTERY OFF
Thanks for your help,
Charging Champions
FTC Team 8660
Unread 05-02-2015, 09:54
ForgotSemicolon's Avatar
ForgotSemicolon ForgotSemicolon is offline
I always forget those semicolons.
FTC #5998 (Ultraviolet)
ForgotSemicolon is an unknown quantity at this point
I would recommend:
- checking your motor wiring. This has caused issues for us before.
- swapping out the motor controller with another one
- making sure code declares motors correctly.
Unread 05-02-2015, 18:17
jcarr jcarr is offline
Coach
FTC #3539
jcarr has much to be proud ofjcarr has much to be proud ofjcarr has much to be proud ofjcarr has much to be proud ofjcarr has much to be proud ofjcarr has much to be proud ofjcarr has much to be proud ofjcarr has much to be proud of
The process I might go through:
1) I would do is make sure there is a red LED that is on when main power is "on"
2) Double check the RJ-45's to the controller. push them in again. Make sure that you know the sequence of controllers coming from the NXT.
3) pull gently on the power wires and the wires that go to the motor to make sure they are firmly connected.
4) Check "motors and sensors" setup and make sure that it is defined correctly in the code,
5) check that the code that tells the motors to go is working.
6) Get a new motor and plug it into the controller. Don't remove the existing motor, just have the new motor loose and plug the white connector into it (or screw in the Neverest). You just want to see if the motor is turning.
