Go to Post I think FIRST is probably close to the farthest you can get from 'gangsta', outscored only by the math team. - Tom Bottiglieri [more]
Unread 05-02-2015, 06:32
MooreteP's Avatar
MooreteP MooreteP is offline
Zen Archer
AKA: Senor Mas
FRC #0571 (Team Paragon)
MooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond repute
Team Update: Drive Team Placement in Playoffs
Searched and surprised to not find a discussion on this:
Team Update 2015-02-03
The higher seeded ALLIANCE will always be assigned to the Red side of the FIELD. Additionally, ALLIANCE CAPTAINS will always be assigned to the center PLAYER STATION, the first pick will be assigned to the station to their left while they’re facing the FIELD, and the second pick will be assigned to their right while they’re facing the FIELD. If a BACKUP TEAM is in play, they will be assigned to the PLAYER STATION that was assigned to the DRIVE TEAM they’re replacing.
In past games, the 1,3 (left,right) positions weren't as differentiated as they are this year. Also, I think their placement varied between Playoff (Elimination) matches.
The 3rd (right) position has a higher potential for drive team vision issues as totes accumulate on the platforms nearest the driver stations. Which they may for yes, chute door, loaders.
The 1st (left) position has the best view of the "aisle" between the stacks. for negotiating the "traffic" between the stacks.
Am I overthinking this?
Unread 05-02-2015, 07:33
StAxis's Avatar
StAxis StAxis is offline
Mentor/Drive Coach
AKA: Zach CH
FRC #1902 (Exploding Bacon)
StAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud of
Re: Team Update: Drive Team Placement in Playoffs
I don't think you're overthinking this at all. For the first time we will see position correlate strongly with your pick. I'm glad they made this change as it will allow for more interesting alliance selections and more consistent team planning. Having set stations for elims is something I've been wanting for years.
I'm really curious if we will see a trend of first seeded landfill bots tanking their last match or two in order to get into that left driver station.
2012 - Engineering Inspiration SFL
2013 - Chairmans SFL, Regional winners SFL
2014 - Engineering Inspiration SFL
2015 - Chairmans GSCR
2016 - Chairmans Rocket City Regional
Unread 05-02-2015, 07:41
MooreteP's Avatar
Zen Archer
AKA: Senor Mas
The potential effects for scouting adds a level that I don't even want to begin to parse.
Unread 05-02-2015, 09:05
jvriezen jvriezen is offline
FRC #3184 (Burnsville Blaze)
jvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond repute
Seems like a better choice would have been to let each alliance captain declare which slot each team is in--but it would apply to all matches (vs. having to deal with logistics of informing FTA each match)
John Vriezen
FRC, Mentor, Inspector #3184 2016- #4859 2015, #2530 2010-2014 FTC Mentor, Inspector #7152 2013-14
Unread 05-02-2015, 09:22
Caleb Sykes's Avatar
Caleb Sykes Caleb Sykes is online now
FRC #4536 (MinuteBots)
I really like the set positions. The alliance captain's coach should be managing the entire alliance, and this is most easily done from the center station. Additionally, since the playoff schedule is already known (5.4.4), queuers won't have to be scrambling so much to tell teams that their match is coming up and which alliance station each team owns.
I don't really like that the higher alliance is red, since red is at a disadvantage when placing robots for autonomous. At lower levels, this effect will be negligible, but I could see it giving blue a leg-up at higher level competitions.
If order placement of ROBOTS matters to either or both ALLIANCES, the ALLIANCE must notify the Head REFEREE during setup for that MATCH. Upon notification, the Head REFEREE will require ALLIANCES to alternate placement of their ROBOTS, starting with the Red ALLIANCE.
Unread 05-02-2015, 09:43
MrTechCenter's Avatar
MrTechCenter MrTechCenter is offline
INTENSITY
AKA: Harsharan "Harsh" Dhaliwal
FRC #2073 (Eagleforce)
MrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant future
I still don't understand why the order of placement would matter. But going back to the point, I like that the alliance captain gets the center driver station for easy communication, but this would have made more sense in Aerial Assist. For Recycle Rush, the position of your driver station could very well effect your strategy, and having the stations assigned makes it rather tough.
2011 Sacramento Regional Finalists; 2011 MadTown Throwdown VIP Excellence in Engineering Award; 2012 Sacramento Regional Innovation in Control Award; 2012 Silicon Valley Regional Judges' Award; 2012 CalGames Autonomous Challenge Award; 2012 MadTown Throwdown Finalists; 2013 P0W3RH0U53 PWNAGE Gracios Professionalism Award; 2014 Central Valley Regional Innovation in Control; 2014 Sacramento Regional Innovation in Control; 2014 Curie Division Gracious Professionalism Award; 2015 Sacramento Regional Innovation in Control
Unread 05-02-2015, 09:46
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
For well-practiced teams, it shouldn't.
Hi!
Unread 05-02-2015, 09:48
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Order of placement matters for alliances planning on battling for the center recycling containers in autonomous. It has nothing to do with being "well practiced" or otherwise.
Unread 05-02-2015, 09:58
Taylor's Avatar
AKA: @taylorstem
What does alliance station position have to do with robot placement on the field?
Hi!
Unread 05-02-2015, 10:01
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
It doesn't. See the quote in Caleb's post above.
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 05-02-2015, 10:05
Professional Stat Padder
While this is an interesting point I hadn't heard anyone make yet, I don't think alliance station placement will shake up rankings or picking too much. While it would be ideal for certain robots to be at certain stations, the difference with good drivers should be small.
I could, however, see a team that is between two different teams to pick making their decision between the two based on alliance station placement.
(2015-Present)
Unread 05-02-2015, 10:33
Taylor's Avatar
AKA: @taylorstem
I see. I was confusing "order placement" as 2-1-3 in the driver station rather than the intended order of robots across alliances placed on the field. My mistake.
For alliance captains 6, 7, and 8, I absolutely agree. Especially at larger events.
Hi!
Unread 05-02-2015, 10:43
Definitely for the 8 seed. They have the ability to pick who goes where if they pick intelligently.
(2015-Present)
Unread 05-02-2015, 10:52
JB987 JB987 is offline
AKA: Joe Barry
FRC #0987 (HIGH ROLLERS)
JB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond repute
As Caleb"s post points out, it looks like highest seeded alliance (red) is no longer a desirable status?
"If order placement of ROBOTS matters to either or both ALLIANCES, the ALLIANCE must notify the Head REFEREE during setup for that MATCH. Upon notification, the Head REFEREE will require ALLIANCES to alternate placement of their ROBOTS, starting with the Red ALLIANCE."
Why would the GDC give such a potential advantage for auto set up to the Blue alliance? Or am I misinterpreting something?
"A genius is just a talented person who does his homework" T. Edison
Unread 05-02-2015, 11:25
AllenGregoryIV's Avatar
AllenGregoryIV AllenGregoryIV is online now
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
I think you read it right, as it stands the GDC is helping out the underdog alliance in this case.
