Go to Post I think this is the forest that ChiefDelphi often misses as we're picking the branches off every tree. - Libby K [more]
Unread 05-02-2015, 11:23
KettleFallsTeam KettleFallsTeam is offline
FRC #4980
KettleFallsTeam is an unknown quantity at this point
Re: Pneumatic Control Module Power Issue
Well, we replaced the fuse and we are getting the same results. However, after listening to the discussion here, we must have burned out the fuse while playing with things after it was already not working. We have checked some of the parts on the board. The little fuse on the PCM is still good. Voltage is going in to the pins on the board. Unfortunately, the overnight shipping to Washington state is $70 but, I'm thinking we will just do the advantage shipping as saving one day doesn't justify the $70. If only they could fulfill the order faster than three days.
Thanks for the all the help, we have an electrical engineer poking around the board right now as I type so, I will keep people posted on what may have happened.
Cheers!
Canine Crusaders #4980
