Go to Post Chain stretch debigulates drive train performance. - Richard Wallace [more]
Unread 05-02-2015, 10:09
kmateti kmateti is offline
FRC #3494
kmateti is an unknown quantity at this point
Re: [C++] Use CAN Talons in RobotDrive
Please post your progress... we have the same exact need, and are hard coding our drive code currently... CAN has so many benefits, but so does using RobotDrive...
Thanks!
Unread 05-02-2015, 10:15
1452-Leo 1452-Leo is offline
FRC #1452 (Omnicats)
1452-Leo is an unknown quantity at this point
Thanks!
We haven't had any time to test really, so we have just hardcoded the Mecanum drive with no gyro. I hope that we can get RobotDrive sorted out later today, but I'm not too sure. Of course I'll post the solution here though if we find it!
Unread 05-02-2015, 11:43
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
This might help, I ran this code on my mec bot, with gyro and CANTalons. I use IterativeRobot (it's just my preference).
http://www.chiefdelphi.com/forums/sh...3&postcount=20
Unread 05-02-2015, 12:08
Thanks! I'll have to try this later. I did just get RobotDrive working by putting this before the drive function:
leftFront->SetControlMode(CANSpeedController::kPercentVbus);
leftBack->SetControlMode(CANSpeedController::kPercentVbus);
rightFront->SetControlMode(CANSpeedController::kPercentVbus);
rightBack->SetControlMode(CANSpeedController::kPercentVbus);
There are problems with this solution though. For example, I can't reverse the motors anymore (it doesn't drive as soon as I add SetInvertedMotor in). I have another idea though that I will try later.
Unread 05-02-2015, 20:41
Ok I got it working! It's kind of an unusual workaround, but it works fine for us. Basically, create 4 fake motor controllers on unused PWM ports, and pass those to RobotDrive. From there, set the values of the real motor controllers to the values of the fake ones. Here is part of the code we used:
CANTalon *leftFront = new CANTalon(1); //Real ones
CANTalon *leftBack = new CANTalon(5);
CANTalon *rightFront = new CANTalon(2);
CANTalon *rightBack = new CANTalon(6);
TalonSRX *PWMlf = new TalonSRX(0); //Fake ones
TalonSRX *PWMlb = new TalonSRX(1);
TalonSRX *PWMrf = new TalonSRX(2);
TalonSRX *PWMrb = new TalonSRX(3);
void TeleopPeriodic()
	drive->MecanumDrive_Cartesian(driveStick->GetX(), driveStick->GetY(), driveStick->GetZ(), gyro->GetAngle());
	leftFront->Set(PWMlf->Get());
	leftBack->Set(PWMlb->Get());
	rightFront->Set(PWMrf->Get());
	rightBack->Set(PWMrb->Get());
Unread 05-02-2015, 21:27
ozrien's Avatar
Omar Zrien
AKA: Omar
The problem looks like it's motor safety tripping. I reproduced the symptom with a similar project. Either the robot hits the motor safety trip once it boots up, or it fires during disable-to-enable transitions. When this happens the driver station will throw the MotorSafetyHelper assert (Section 16.14 in Talon SRX software reference manual), and the self-test will report "No-drive ".
I bet if you just called m_robotDrive->SetLeftRightMotorOutputs(0,0) in the disabled loop, that will keep feeding the motor safety object often enough to prevent your problem.
Or alternatively just TURN OFF the feature with...
m_robotDrive->SetSafetyEnabled(false)
Using dummy PWM objects seems like a drastic workaround.
Here's what I tested. If you comment out DisabledPeriodic(), you can reproduce the problem.
#include "WPILib.h"
class MecanumDefaultCode : public IterativeRobot
	CANTalon lf; /*left front */
	CANTalon lr;/*left rear */
	CANTalon rf; /*right front */
	CANTalon rr; /*right rear */
public:
	RobotDrive *m_robotDrive;		// RobotDrive object using PWM 1-4 for drive motors
	Joystick *m_driveStick;			// Joystick object on USB port 1 (mecanum drive)public:
	Gyro gyro;
	 * Constructor for this "MecanumDefaultCode" Class.
	MecanumDefaultCode(void) : lf(3), lr(1), rf(4), rr(5),  gyro(0)
		// Create a RobotDrive object using PWMS 1, 2, 3, and 4
		m_robotDrive = new RobotDrive(lf, lr, rf, rr);
		/* alternatively you can disable safety features if you are not source-level debugging.
		 * uncomment this line to disable safety features. */
		//m_robotDrive->SetSafetyEnabled(false);
		// Define joystick being used at USB port #0 on the Drivers Station
		m_driveStick = new Joystick(0);
	void TeleopInit()
		gyro.Reset();
	/** @return 10% deadband */
	double Db(double axisVal)
		if(axisVal < -0.10)
			return axisVal;
		if(axisVal > +0.10)
			return axisVal;
		return 0;
	void DisabledPeriodic(void)
		/* while we are disabled, keep calling robotDrive's
		 * set routine to keep feeding the safety helper */
		m_robotDrive->SetLeftRightMotorOutputs(0,0);
	 * Gets called once for each new packet from the DS.
	void TeleopPeriodic(void)
		/* grab angle */
		float angle = gyro.GetAngle();
		/* printf for debugging - leave commented so it does affect performance. */
		//std::cout << "Angle : " << angle << std::endl;
		/* use angle with mec drive */
		m_robotDrive->MecanumDrive_Cartesian(	Db(m_driveStick->GetX()),
												Db(m_driveStick->GetY()),
												Db(m_driveStick->GetZ()),
												angle);
		/* my right side motors need to drive negative to move robot forward */
		m_robotDrive->SetInvertedMotor(RobotDrive::kFrontRightMotor,true);
		m_robotDrive->SetInvertedMotor(RobotDrive::kRearRightMotor,true);
START_ROBOT_CLASS(MecanumDefaultCode);
Unread 05-02-2015, 23:19
I tried turning the safeties off already and it didn't work, but I'll try the disabled loop tomorrow and get back. I agree that dummy PWMs is a bad solution, but we're going all CAN this year so it shouldn't really affect anything, and we will probably revert to it if your solution doesn't work because we've spent too long trying to get this to work. Thanks for the help though!
Unread 07-02-2015, 21:14
ozrien's Avatar
Omar Zrien
AKA: Omar
Turning off the safeties in the CANTalons is not sufficient. They are already off (they default off). The problem is RobotDrive has it's own safety enable.
Anyway if you are still seeing the EXACT symptom of "...Motor Safety Timeout..." errors in the DS then you need to remedy it. Even with the PWM workaround (eek) you're still generating errors in your DS log. That's going to prevent your drive team from seeing other reported errors (because they will get used to seeing errors in that area of the DS".
m_robotDrive->SetSafetyEnabled(false); will absolutely prevent MS errors. If you are still seeing them then something is very wrong, and it will likely be a problem throughout the season.
Unread 13-02-2015, 17:54
AKA: Brad
#0190 ( Gompei and the Herd)
Definitely turn off the motor safety on the RobotDrive object, not the individual motor controllers and see if that fixes the problem. In the library, RobotDrive is the only place where the motor safety stuff is enabled by default, and as Omar said, it is part of the RobotDrive class as a whole. The thought was that it would stopping the runaway program from driving on it's own was the highest priority.
Use something like:
drive.SetSafetyEnabled(false);
Please let us know if does it for you.
Brad Miller
Robotics Resource Center
