Go to Post The person that I would, without a doubt, would like to meet the most is my sanity. - lukevanoort [more]
Unread 04-02-2015, 22:05
Jared's Avatar
Jared Jared is offline
Vex Pro #25 Chain Master Link Source
The Vex Pro #25 chain requires a weird master link with longer pins and thicker side plates. A master link that meets the ANSI standard doesn't work, but we aren't sure exactly what the heavy-duty master link is. We have a master link that's classified as "heavy duty" on the package, but meets the ANSI standard. Vex's heavy duty master link does not.
Vex is out of stock of the heavy duty master link. Where can we purchase a master link that will work with the vex chain?
Unread 04-02-2015, 22:12
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Re: Vex Pro #25 Chain Master Link Source
Team 221 sells a Dark Soul chain tool for #25 chain. It's available from a few different suppliers online. It allows you to break and rejoin chain without any master links; we use it all the time now. Why not contact vex about the strength of the master link?
Unread 04-02-2015, 22:16
Owen Busler's Avatar
Owen Busler Owen Busler is offline
Build Captain
FRC #0303 (Test Team)
Owen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant future
Although it is much more difficult, it is worth it in the long run just to re-assemble the chain. This is usually done with the flip side of a chain breaker. A tool like this works well:
http://www.team221.com/viewproduct.php?id=70
Unfortunately it is out of stock
Good luck with the rest of your season.
Unread 04-02-2015, 22:18
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
We actually have had a harder time with master links than with the tool, espcially the thin c-shaped plate that always seems to get lost.
Unread 04-02-2015, 22:30
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
Hmmm this is very concerning. I haven't used 25 chain before sadly with this year being my first. I've been so used to ordering 35 chain from AndyMark or Vex and getting masterlinks from either AM or McMaster so I went about 25 the same way with 25 chain from Vex and master links from McMaster (because they were out of stock at Vex). I'm only now noticing the disclaimer that only the master links below (which are conveniently out of stock) work with Vex chain.
We were hoping to do assembly this Friday and over the weekend so would that mean my next best bet is to order chain from McMaster? I need close to 120ft so $5 per foot is robbery compared to $1 per foot from Vex.
Any concerns about using Vex sprockets with other sourced chains?
Insert panic.
1058 PVC Pirates 2016 - xxxx
Unread 04-02-2015, 22:35
Joe G.'s Avatar
Joe G. Joe G. is online now
AKA: Josepher
no team (Formerly 1687, 5400)
Insert panic.
Andymark #25 works fine with McMaster master links, and is only slightly pricier than Vex chain.
Unread 04-02-2015, 22:58
Michael Hill's Avatar
http://www.therobotspace.com/Product...e=vex-217-2998
Unread 04-02-2015, 23:03
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
Originally Posted by Michael Hill View Post
Awesome, thanks!
Unread 04-02-2015, 23:09
Originally Posted by s_forbes View Post
Awesome, thanks!
Since you're in Arizona, West Coast Products might be a quicker choice: http://www.wcproducts.net/roller-chain
Unread 04-02-2015, 23:11
Ty Tremblay's Avatar
Ty Tremblay Ty Tremblay is online now
Robotics Engineer
FRC #0319 (Big Bad Bob)
http://www.electricscooterparts.com/chain25.html
Unread 04-02-2015, 23:24
Aren_Hill's Avatar
Build Nifty Things
#25H master links from other sources work on our stuff as well, nothing super special about ours.
-Aren
A guy who likes robots.
Unread 05-02-2015, 12:37
AKA: Brendan Browne
Figured this could help someone else out. I found what looks like the same chain break as the ones from 221 shipping out of Utah.
Just got off the phone and they are sending that out today.
http://www.davesmotors.com/s.nl/it.A/id.2258/.f
Unread 05-02-2015, 12:50
AdamHeard's Avatar
Lead Mentor
use coupon code DDM for 5% off.
Always google for coupon codes before ordering is a nice trick someone told me.
