Thread Tools |
Rating:
Display Modes |
Re: Team Update: Drive Team Placement in Playoffs
Beyond the impact at regional events, the implications for Einstein are huge. At least in a subdivision or at a regional, you can plan and prepare for the situations you will be facing when making your selections.
On Einstein, where this rule will have the greatest impact, presumably, the "seeds" will be randomly set, and some divisions will have an inherent advantage, by no doing of their own. I'm not committed to this idea, but one way to at least make it feel more fair would be with a ABBAAB format. It would also save time, since the current way presumably could take up to 6 minutes, since each team needs to set up their robot. |
I don't think of it as pulling the top down, I think of it as pushing the top and the bottom closer together. (sorry if this is derailing a thread, it's kind of a pet peeve of mine.) |
So if one is uncomfortable with the higher seed "earning" an advantage then why not argue for alternating second placement status during auto set up with each match played?
The Q&A was answered, and confirms this Blue alliance advantage:
I don't think that the draft order completely balances the issue, by the way, but I also don't think that it should balance out perfectly. I believe that the tournament rules should provide incentive to be the first seed. This new rule provides a unique penalty to being first seed; they will never by anything but the red alliance and be at a significant disadvantage in all of the playoffs matches and in the actual finals for an event. This will also play out very strangely on Einstein this year where teams come from different fields; will four alliances will win the lottery and be assigned the color blue? Actually, I am not sure that they have defined the process for picking alliance colors on Einstein...I can't find that information in the manual. Edited to add: I do think that there are a variety of equalization strategies that could also be employed as well (as others have mentioned). Robot placement could alternate from game to game: Red-then-Blue in one game and then Blue-then-Red in the next game. You could also just flip a coin before each match to make the advantage less predetermined or less one-sided. Last edited by mmaunu : 06-02-2015 at 12:38. Reason: Added "Edited to add" section |
#10
Blue only can use the advantage if they have robots that are able to capitalize on it. They still have to be faster than the other team. All the placement advantages in the world, won't make the RCs come off the step any faster for you. By giving blue this advantage assuming both alliances has some sort of staggered RC grappling (some of them come off the step faster than others) we are likely allowing Blue to get some but not all the containers, if Red does have at least a faster initial pull of one or more RCs.
Basically what I'm saying is yes the GDC is giving blue an advantage but if Red is faster they still get some of the RCs and you probably have a more even distribution of RCs because of this. (2-2, or 3-1 instead of 4-0). Since Blue can put their faster puller against Red's slower puller (or later RCs if it's one robot doing all 4). Man we really need to lock down a vocabulary for some of these things. |
#11
If Red is a few seconds faster this could be a mute issue depending on how both Blue and Red collect their RCs but as the season progresses and teams get faster the GDC is giving favor to the Blue alliance. IMHO have the head referee do a coin toss if an order needs to be determined. Blue alliances shouldn't be guaranteed the upper hand in autonomous. |
#12
My guess is this doesn't matter until Week 5+. I'm betting there are teams that will dominate the RCs early on and position and order won't matter. As the season progresses it will be like Minibots and teams will catch up.
#14
According to 5.4.4 the seeding is redone after the quarters, and again after the semi's.
You may notice that the #1 seed gets to play last in QF4 and QF8. That gives them the opportunity to pre-calculate the score they need to come in 4th and sandbag the match a little (if ensuring the blue autonomous advantage was important to them). Moving from the semi's to the finals is not as easy to control from that spot though since Q4 plays their last match against Q3 before Q1 and Q2 play theirs. (Side note: I could foresee a scenario where Q1 and Q2 both score enough to advance in the last semi-final, but battle each other for the right to be blue in the finals by scoring as close to the minimum number of points needed to edge out Q3 and Q4.) Now what about Einstein... Will the positioning of the 8 subdivision winners be random or based on their Qualification Average in the subdivision finals? Section 5.6 is a little thin on this area. Help me out if I overlooked something. |
#15
But also interesting. What if you score the minimum number of points needed to advance, but then in the last few seconds an errant noodle or robot knocks over a stack. What is your course of action? How important is that slight advantage to you? |
