Go to Post Don't forget the robot, the most important hardware there is!:p - artK [more]
Unread 05-02-2015, 11:50
PayneTrain's Avatar
PayneTrain PayneTrain is offline
Trickle-Down CMP Allocation
AKA: Lizard King
FRC #0422 (The Meme Tech Pneumatic Devices)
Team Role: Mascot
PayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond repute
Re: Team Update: Drive Team Placement in Playoffs
Originally Posted by JB987 View Post
As Caleb"s post points out, it looks like highest seeded alliance (red) is no longer a desirable status?
"If order placement of ROBOTS matters to either or both ALLIANCES, the ALLIANCE must notify the Head REFEREE during setup for that MATCH. Upon notification, the Head REFEREE will require ALLIANCES to alternate placement of their ROBOTS, starting with the Red ALLIANCE."
Why would the GDC give such a potential advantage for auto set up to the Blue alliance? Or am I misinterpreting something?
Since it's part of an update, I imagine they intended to write it so the robot setup advantages favor the higher seeded alliance and they will fix it later. If it doesn't change before week 1, well, whatever.
The static placement of teams based on intra-alliance standing is a boon for logistics at the team, alliance, and field operation levels. Drive teams always know where they are setting up, alliance captains are always at the best station for coordinating, MC and GA always know which team will be the alliance captain by just looking at the field, as will spectators, etc.
Here is a thought: if you are an alliance captain, how much stock are you putting into HP placement? Do you want the 2 HP to be next to 2 station, 3 HP next to 3 station, and your HP running some tactical function like the 2011 HP not at the slots? You could even say there might be an opportunity if the 2 and 3 HPs are similar enough to the 1 HP that your 1 HP could be coached up on helping to coordinate 1 Drive Team while 1 Coach operates as a field marshal of sorts, understanding and accepting some obvious tradeoffs with this move.
Unread 05-02-2015, 12:10
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
It depends on the alliance captains robot. If they are a slot feeder, they will have their trained HP at the slot. It's like 2013, you don't want just anybody feeding your robot.
Unread 05-02-2015, 12:40
PayneTrain's Avatar
AKA: Lizard King
Team Role: Mascot
I mean, teams that made their robots almost idiot proof w/ regards to catching a pass from an HP (from literal targets to software compensation to "just throw it in this large hole, you can't miss it) in 2014 were fine. You want someone who can tell your robot is properly aligned or within an acceptable range of degrees of the slot before they start opening the chute door, but the chute this year is so much slower than the 2013 chutes having a fast HP is almost not even a real thing.
You are making a tradeoff if you pull a familiar HP for the purposes of better coordination between teams, and I don't even know if it could be worth it yet. It's just something I'm going to simmer over for a bit.
Unread 05-02-2015, 12:42
AdamHeard's Avatar
Lead Mentor
I hope this isn't an attempt to level the playing field by dragging the top down (like the serpentine draft).
Unread 05-02-2015, 13:13
mmaunu's Avatar
mmaunu mmaunu is offline
FRC #2485 (W.A.R. Lords)
mmaunu is a jewel in the roughmmaunu is a jewel in the roughmmaunu is a jewel in the roughmmaunu is a jewel in the rough
This is something that I would like to ask in the Q&A but it also seems inappropriate for Q&A since the rule is incredibly clear. Is there a forum for asking "Why did this rule (about red placing robots on the field before blue) get made when it clearly gives a disadvantage to the higher seeded alliance even though they earned the right to have the advantage?"?
Did they, perhaps, give the advantage to the lower-seeded alliance in an attempt to balance the play? That seems particularly rough in the Finals matches and/or at high levels of play where both sides will be vying for the center containers.
2014 Las Vegas (Winners with 987, 2478; Excellence in Engineering)
2014 San Diego (Finalists with 987, 3250; Quality Award)
2013 Inland Empire (Winners with 1538, 968; Excellence in Engineering Award)
2013 San Diego (Finalists with 2984, 4322; Creativity Award)
2012 Las Vegas (Finalists with 2034, 3187; Quality Award)
Last edited by mmaunu : 05-02-2015 at 13:16. Reason: Added clarity to vague section...I hope
Unread 05-02-2015, 13:17
EdwardP's Avatar
EdwardP EdwardP is offline
FRC #0971 (Spartan Robotics)
Team Role: Tactician
EdwardP is a jewel in the roughEdwardP is a jewel in the roughEdwardP is a jewel in the roughEdwardP is a jewel in the rough
Beyond the impact at regional events, the implications for Einstein are huge. At least in a subdivision or at a regional, you can plan and prepare for the situations you will be facing when making your selections.
On Einstein, where this rule will have the greatest impact, presumably, the "seeds" will be randomly set, and some divisions will have an inherent advantage, by no doing of their own.
I'm not committed to this idea, but one way to at least make it feel more fair would be with a ABBAAB format. It would also save time, since the current way presumably could take up to 6 minutes, since each team needs to set up their robot.
Unread 05-02-2015, 13:20
Rachel Lim Rachel Lim is online now
FRC #1868 (Space Cookies)
Team Role: Student
Rachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond repute
I'm guessing that Q316 and Q317 ask your question:
Originally Posted by Q317
Sec 5.1 states that "...require ALLIANCES to alternate placement of their ROBOTS, starting with the Red ALLIANCE.", implying that the order of ROBOT placement is Red, Blue, Red, Blue, Red, Blue. Sec 5.4.4 states that during Playoff MATCHES "The higher seeded ALLIANCE will always be assigned to the Red side of the FIELD" This implies that the lower seeded alliance (blue) is given the advantage of placing last and reacting to their higher seeded opponent (red). Is this the intent of the rule?
Unread 05-02-2015, 14:01
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
I'm not sure why these new rules came out in this update?
If anything, why not let teams decide which alliance station they want. Its been done before at offseason events and allows teams to comfortably choose where they want to be, optimizing vantage points for the entire alliance. To some extent it does matter. Some drivers are tall, some short and anyone that has ever coached behind the glass will tell you that the view is much different than for a spectator seeing the whole field.
The field isnt symmetrical with respect to each alliance.
The only reason I see that red places their bots first, is to level the playing field as others have suggested.
Unread 05-02-2015, 14:02
Joseph1825 Joseph1825 is offline
FRC #1825
Joseph1825 has a spectacular aura aboutJoseph1825 has a spectacular aura aboutJoseph1825 has a spectacular aura about
Wait, did I miss something? I always thought of the serpentine draft as one of the best things for FIRST competitiveness. If you check the numbers the first alliance (and thus the first seed), still win over 50% of all regionals. IMO the serpentine draft is one of the only things making the lowest five alliances competitive.
I don't think of it as pulling the top down, I think of it as pushing the top and the bottom closer together.
(sorry if this is derailing a thread, it's kind of a pet peeve of mine.)
New goal: Take mecanums to Einstein!
Unread 05-02-2015, 15:43
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Barring some sort of pre-recorded position cards you hand to the ref before a match, robot positioning is a zero-sum thing. One team will have to place their robot first. This is just as much of raising the floor as it is "dragging the top down."
You think the rankings will be a perfect estimation of what was "earned" on the field? You don't think scheduling will still have a large impact on average scores? Do you think that being the higher seed automatically entitles you to all of the advantages?
Unread 05-02-2015, 16:19
JB987 JB987 is offline
AKA: Joe Barry
FRC #0987 (HIGH ROLLERS)
JB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond repute
So if one is uncomfortable with the higher seed "earning" an advantage then why not argue for alternating second placement status during auto set up with each match played?
"A genius is just a talented person who does his homework" T. Edison
Unread 05-02-2015, 17:06
mmaunu's Avatar
  1. I don't think that the rankings are a perfect estimation of what was "earned" on the field but the ranking system is what it is and it is used to determine relative ranks. These ranks typically come with perks for being higher ranked (so that there is a tournament-specific incentive to rank well).
  2. I think that scheduling will have a large impact on average scores...just like it has these last many years.
  3. I do think that being the higher seed entitles you to having advantages in general and having the advantage in this particular situation. This rule gives a very significant disadvantage to the higher-seeded team, a disadvantage that is not balanced by any other factor and one that might decide finals matches in many events.
Unread 06-02-2015, 09:53
Josh Fritsch's Avatar
Josh Fritsch Josh Fritsch is offline
Team 27 Mentor/Alumni
FRC #0027 (Team Rush)
Josh Fritsch has a spectacular aura aboutJosh Fritsch has a spectacular aura about
The Q&A was answered, and confirms this Blue alliance advantage:
Q317 Q. Sec 5.1 states that "...require ALLIANCES to alternate placement of their ROBOTS, starting with the Red ALLIANCE.", implying that the order of ROBOT placement is Red, Blue, Red, Blue, Red, Blue. Sec 5.4.4 states that during Playoff MATCHES "The higher seeded ALLIANCE will always be assigned to the Red side of the FIELD" This implies that the lower seeded alliance (blue) is given the advantage of placing last and reacting to their higher seeded opponent (red). Is this the intent of the rule?
A. Sections 5.1 and 5.4.4 are correct as written, and as you have described in your question.
Unread 06-02-2015, 10:00
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Not balanced by any other factor? Getting an earlier pick in alliance selection is certainly balancing it via another factor, I'd say.
Unread 06-02-2015, 12:15
mmaunu's Avatar
I do think that first seed getting an earlier alliance selection is an advantage, but I also think that the serpentine draft is a balancing factor for that. Since the rules have an existing balancing mechanism for getting to pick first, this new rule seems to come without a complementary balancing factor. In fact, I submit that, at some events, there might be a distinct advantage to being the second alliance captain. That design decision seems like a bad idea to me.
I don't think that the draft order completely balances the issue, by the way, but I also don't think that it should balance out perfectly. I believe that the tournament rules should provide incentive to be the first seed. This new rule provides a unique penalty to being first seed; they will never by anything but the red alliance and be at a significant disadvantage in all of the playoffs matches and in the actual finals for an event.
This will also play out very strangely on Einstein this year where teams come from different fields; will four alliances will win the lottery and be assigned the color blue? Actually, I am not sure that they have defined the process for picking alliance colors on Einstein...I can't find that information in the manual.
Edited to add: I do think that there are a variety of equalization strategies that could also be employed as well (as others have mentioned). Robot placement could alternate from game to game: Red-then-Blue in one game and then Blue-then-Red in the next game. You could also just flip a coin before each match to make the advantage less predetermined or less one-sided.
Last edited by mmaunu : 06-02-2015 at 12:38. Reason: Added "Edited to add" section
