When I run my program through the "debug as" and then " WPIlib Java Deploy " the code makes eclipse become "responding" or (Not Responding)
I created this program off of the "getting started" program that comes with the FRC project package org.usfirst.frc.team4284.robot; import edu.wpi.first.wpilibj.IterativeRobot; import edu.wpi.first.wpilibj.Jaguar; import edu.wpi.first.wpilibj.buttons.JoystickButton; import edu.wpi.first.wpilibj.buttons.Button; import edu.wpi.first.wpilibj.Joystick; import edu.wpi.first.wpilibj.RobotDrive; import edu.wpi.first.wpilibj.livewindow.LiveWindow; /** * The VM is configured to automatically run this class, and to call the * functions corresponding to each mode, as described in the IterativeRobot * documentation. If you change the name of this class or the package after * creating this project, you must also update the manifest file in the resource * directory. */ public class Robot extends IterativeRobot { RobotDrive Drive; Joystick drivestick; Joystick xbox; int autoLoopCounter; /** * This function is run when the robot is first started up and should be * used for any initialization code. */ public void robotInit() { Jaguar FL = new Jaguar (1); Jaguar BL = new Jaguar (2); Jaguar FR = new Jaguar (3); Jaguar BR = new Jaguar (4); Drive = new RobotDrive(FL,BL,FR,BR); drivestick = new Joystick(0); xbox = new Joystick(1); } /** * This function is run once each time the robot enters autonomous mode */ public void autonomousInit() { autoLoopCounter = 0; } /** * This function is called periodically during autonomous */ public void autonomousPeriodic() { /*if(autoLoopCounter < 100) //Check if we've completed 100 loops (approximately 2 seconds) { Drive.drive(-0.5, 0.0); // drive forwards half speed autoLoopCounter++; } else { Drive.drive(0.0, 0.0); // stop robot } */ } /** * This function is called once each time the robot enters tele-operated mode */ public void teleopInit(){ Button button1 = new JoystickButton(xbox, 1), button2 = new JoystickButton(xbox, 2), button3 = new JoystickButton(xbox, 3), button4 = new JoystickButton(xbox, 4), button5 = new JoystickButton(xbox, 5), button6 = new JoystickButton(xbox, 6), button7 = new JoystickButton(xbox, 7); button1.whenPressed(new ElevatorReverse()); button2.whenPressed(new ElevatorOn()); button3.whenPressed(new ElevatorOff()); button4.whenPressed(new ArmsOut()); button5.whenPressed(new ArmsIn()); button6.whenPressed(new ArmsVerticalIn()); button7.whenPressed(new ArmsVarticalOut()); } /** * This function is called periodically during operator control */ public void teleopPeriodic() { Drive.arcadeDrive(drivestick); } /** * This function is called periodically during test mode */ public void testPeriodic() { LiveWindow.run(); } } |
Re: Java - "debug as " problem
What happens if you wait a little while? On my computer, it freezes for around 5-7 seconds and then starts working again. I think this might be due to having to connect to the roboRIO over the network.
