Go to Post I've ridden the real Segway many times and I think it is a truly remarkable machine and worth every cent (if you have enough cents to spend on it). - sanddrag [more]
Unread 04-02-2015, 10:06
crollison crollison is offline
AKA: Chris Rollison
FRC #4809 (Black Knight Robotics)
crollison is an unknown quantity at this point
CAT5 for Solenoid Connections
If I'm reading things correctly, we can legally use CAT5 to run from the PCM to the solenoids, correct? Rule book shows a minimum of 28 AWG and Wikipedia shows CAT5 as 24AWG. Just making sure before we pull wire. The goal this year is to pass inspection first time.
Unread 04-02-2015, 10:32
ASmith1675's Avatar
ASmith1675 ASmith1675 is offline
Mechanical/Electrical/Scouting
AKA: Adam Smith
ASmith1675 is a splendid one to beholdASmith1675 is a splendid one to beholdASmith1675 is a splendid one to beholdASmith1675 is a splendid one to beholdASmith1675 is a splendid one to beholdASmith1675 is a splendid one to beholdASmith1675 is a splendid one to beholdASmith1675 is a splendid one to behold
Re: CAT5 for Solenoid Connections
We did this a few years ago and didn't have any issues with inspection. Be prepared to explain these connections (we did have to do this -- not everyone knows what gauge wire is contained in CAT5 cable).
I am not, however, an inspector of any type so I defer to their expertise if they have anything that contradicts me on this.
Unread 04-02-2015, 10:55
tr6scott's Avatar
tr6scott tr6scott is offline
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
tr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond repute
There are different gauges for CAT5, so if the gauge is not printed clearly on the cable, have a cut sheet of the CAT5 you used showing gauge.
The sooner we get behind schedule, the more time we have to catch up.
Unread 04-02-2015, 11:12
Alternately, locate your PCM near the solenoids, and just run your CAN cables there.
Unread 05-02-2015, 12:47
Chris,
You are correct as to the wire gauge. However, I always caution teams that using solid wire on moving devices like a robot beg for wire fatigue and failure. We rarely use solid wire and then only when very secure so that it will not move. Essential wiring gets changed out whenever suspect.
Unread 05-02-2015, 20:47
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
Chris,
^This, In 2011 I remember learning about such the hard way. However, swapping to stranded cat5 fixed the issue...
Unread 05-02-2015, 22:26
IceStorm IceStorm is offline
Mentor FRC 5046, FTC 8688
AKA: Chad
FRC #5046 (Jacked Up Jackets)
IceStorm is a glorious beacon of lightIceStorm is a glorious beacon of lightIceStorm is a glorious beacon of lightIceStorm is a glorious beacon of lightIceStorm is a glorious beacon of light
Send a message via AIM to IceStorm Send a message via Yahoo to IceStorm
You can get stranded cat5 cable. Most patch cords are made of this. It's only the stuff that gets ran in the walls that is solid usually.
