Go to Post We are not the families of competiting robot teams, but we are a family of Gracious and Professionalism, because we know it better than anyone in the world. - wsansewjs [more]
Unread 02-05-2015, 12:46 PM
AnnaliseDonavan AnnaliseDonavan is offline
FRC #4284
AnnaliseDonavan is an unknown quantity at this point
Exclamation Java - "debug as " problem
When I run my program through the "debug as" and then " WPIlib Java Deploy " the code makes eclipse become "responding" or (Not Responding)
I created this program off of the "getting started" program that comes with the FRC project
package org.usfirst.frc.team4284.robot;
import edu.wpi.first.wpilibj.IterativeRobot;
import edu.wpi.first.wpilibj.Jaguar;
import edu.wpi.first.wpilibj.buttons.JoystickButton;
import edu.wpi.first.wpilibj.buttons.Button;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.livewindow.LiveWindow;
* The VM is configured to automatically run this class, and to call the
* functions corresponding to each mode, as described in the IterativeRobot
* documentation. If you change the name of this class or the package after
* creating this project, you must also update the manifest file in the resource
* directory.
public class Robot extends IterativeRobot {
RobotDrive Drive;
Joystick drivestick;
Joystick xbox;
int autoLoopCounter;
* This function is run when the robot is first started up and should be
* used for any initialization code.
public void robotInit() {
Jaguar FL = new Jaguar (1);
Jaguar BL = new Jaguar (2);
Jaguar FR = new Jaguar (3);
Jaguar BR = new Jaguar (4);
Drive = new RobotDrive(FL,BL,FR,BR);
drivestick = new Joystick(0);
xbox = new Joystick(1);
* This function is run once each time the robot enters autonomous mode
public void autonomousInit() {
autoLoopCounter = 0;
* This function is called periodically during autonomous
public void autonomousPeriodic() {
/*if(autoLoopCounter < 100) //Check if we've completed 100 loops (approximately 2 seconds)
Drive.drive(-0.5, 0.0); // drive forwards half speed
autoLoopCounter++;
} else {
Drive.drive(0.0, 0.0); // stop robot
* This function is called once each time the robot enters tele-operated mode
public void teleopInit(){
Button button1 = new JoystickButton(xbox, 1),
button2 = new JoystickButton(xbox, 2),
button3 = new JoystickButton(xbox, 3),
button4 = new JoystickButton(xbox, 4),
button5 = new JoystickButton(xbox, 5),
button6 = new JoystickButton(xbox, 6),
button7 = new JoystickButton(xbox, 7);
button1.whenPressed(new ElevatorReverse());
button2.whenPressed(new ElevatorOn());
button3.whenPressed(new ElevatorOff());
button4.whenPressed(new ArmsOut());
button5.whenPressed(new ArmsIn());
button6.whenPressed(new ArmsVerticalIn());
button7.whenPressed(new ArmsVarticalOut());
* This function is called periodically during operator control
public void teleopPeriodic() {
Drive.arcadeDrive(drivestick);
* This function is called periodically during test mode
public void testPeriodic() {
LiveWindow.run();
Unread 02-05-2015, 01:04 PM
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
Re: Java - "debug as " problem
What happens if you wait a little while? On my computer, it freezes for around 5-7 seconds and then starts working again. I think this might be due to having to connect to the roboRIO over the network.
