Thread Tools |
Rating:
Display Modes |
Once your pneumatic system is assembled, I would recommend using last years inspection checklist (or this years if it's posted by then) and then running through the entire checklist. This will ensure you have less hiccups at completions.
Also, if you hear any leaks but cannot find them, you can put soapy water on the areas you think are leaking and you will see air bubbling up where the leak is. Best of luck and welcome to FIRST ![]() |
Re: Help! Rookie with Pneumatics!!!
Ok! Thanks for everyone's advice! I successfully figured out how to set the system up for our robot and it's running good along with my solenoid programming code!
