Go to Post I had so much to say but I dont know how to get it accross -- but to all of you that we were involved with this weekend, thankyou for everything -- we're changing lives, and we truly are moving mountains, in more ways than one. - Jacqui Sutton [more]
Unread 05-02-2015, 14:43
RafaelRamosV RafaelRamosV is offline
FRC #5312
RafaelRamosV is an unknown quantity at this point
Motor Program Issue
Hi partners, I have this little problem, I built a simple code to control the rotation of a motor with two buttons of the joystick, at the moment I tested it, it worked fine to the left, but when I try the right the motor stop and start, then stop and this become a cycle, we try the same code with another computer and it worked perfectly at the first time, so I donīt know what to do, I already update labview but still the same
Unread 05-02-2015, 15:00
Re: Motor Program Issue
Those symptoms are pretty specific. What you have probably done is set up two different pieces of code that each set the motor to either run or stop. What you need to is to connect them so that the motor is only being set in exactly one place.
If you're using Select functions, delete the Motor Set after the first one and wire its output instead to where you used to have a 0 going into the second one.
If you're using Case blocks...use Select functions instead. Look here for an example of how to do it.
Unread 05-02-2015, 16:24
FRC #5312
I have already done that and keep having the problem :S
Unread 05-02-2015, 16:31
Show us your code.
