Go to Post Has FIRST ever made a game that was easy to do? - Koko Ed [more]
Unread 05-02-2015, 15:59
Bochek's Avatar
Bochek Bochek is offline
AKA: Adam Bochek
FRC #2200 (MMRambotics)
Bochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud of
Re: pic: 2200's Progress to date.
Originally Posted by Nate Laverdure View Post
Looks spiffy, but I can't imagine why you decided to implement a lightening pattern that uses 4-sided elements.
A municipal truss bridge with 3-sided elements (triangles)
A municipal truss bridge with 4-sided elements (rhombuses)
The difference is that the individual members of the triangle truss are loaded only in tension and compression, while in the rhombus truss they're also loaded in bending. This additional loading means that each member of the truss must be MUCH stiffer.
Given the thickness of your chassis plates shown in the photo, my gut says the bending strength is acceptable here. But did you perhaps do any FEA on these plates to justify your decision?
No FEA. More thought went into your post then the pattern in our frame plates.
Similar to last years chassis, the cut-outs where designed with a "that'll do" attitude, with a bit of consideration to looks.
- Bochek
Adam Bochek - FRC 2200
http://www.mmrambotics.com
http://www.watchfirstnow.com
