Thread Tools |
Rating:
Display Modes |
Re: Another Unidentified Motor Crisis!
That's an old BaneBots motor and gearbox, which I think came in the 2007 kit of parts. The motor, you could check the numbers, and if you still don't know, you could use a new RS550 type motor to replace it. The gearbox is an old KOP and COTS item, so it should be legal. You have to remove the pinion gear (or buy a new one) to be able to change the motor.
MrForbes is right, it looks like a 550 can size motor (probably Banebots 550) missing the outer sleeve attached to an old Banebots gearbox. They're pretty old, and I only remember the gearboxes giving me problems.
We used a 125:1 Banebots gearbox like that in 2007, and it worked fine all season. We went to a lot of trouble to make sure it would not be overloaded, though.
http://www.chiefdelphi.com/forums/sh...ad.php?t=53009 http://www.chiefdelphi.com/forums/sh...ad.php?t=53185 http://www.chiefdelphi.com/forums/sh...ad.php?t=53766 |
We loved the old 36mm BaneBots gearboxes and used them on nearly every robot we built from 2006 to 2012. They were lightweight and inexpensive and worked great for light high-speed loads. We only stopped using them because they stopped being manufactured -- if we had enough spare parts for them, we'd still be using them, as we really haven't found a replacement for their specific niche.
