Go to Post “Nothing defines humans better than their willingness to do irrational things in the pursuit of phenomenally unlikely payoffs” - Scott Adams - 114Klaatu0x72 [more]
Unread 05-02-2015, 16:27
yonisav yonisav is offline
FRC #4712 (TracBots)
yonisav is an unknown quantity at this point
Can we use this magnetic sensor?
Hello delphy
I found this https://www.controlanything.com/Relay/Device/CKN6004 magnetic sensor in a store (I am giving you an english link for your convenience) and I was wondering if it would be legal for FRC purposes?
I couldn't figure out how it should be operated from it's pdf manual, which is linked here: https://s3.amazonaws.com/assets.cont...rs/CKN6004.pdf
Unread 05-02-2015, 16:33
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Re: Can we use this magnetic sensor?
It looks like a magnetic reed switch. Yes it is legal. It is a custom circuit. Connect it to a Digital input & 0V. The input will read low when the switch is made. (magnet close to switch).
Unread 05-02-2015, 16:46
But will it work with the DIO power output?
Unread 05-02-2015, 17:12
It is a simple switch. It requires no power.
Unread 06-02-2015, 08:50
mshafer1 mshafer1 is offline
Programming Mentor
AKA: Matthew Shafer
FRC #3937 (Breakaway)
mshafer1 is an unknown quantity at this point
This is correct. To add to what Alan said, this would make the switch be active low (i.e. the dio will read false when the switch closes), to make it active high you would connect it to 5v, but because the switch would cause a short circuit in that case you would have to put a resistor in series with it.
In short:
Ground - Switch - Input(on DIO) → active low
5v - switch - resistor (like 3.3k or bigger, but not too big) - input → active high
The first option is simpler, and it is easy to account for in software.
