Go to Post I feel there really is only one team, and the name of that team is FIRST. - [more]
Unread 05-02-2015, 09:41
FRC2501's Avatar
FRC2501 FRC2501 is offline
FRC #2501 (Bionic Poalrs)
FRC2501 is an unknown quantity at this point
TalonSRX invert?
We program in C++ and I was wondering if there is a way to invert TalonSRXs in programming because out Omni drive needs both right motors to be inverted or it acts weird
Unread 05-02-2015, 10:14
Ty Tremblay's Avatar
Robotics Engineer
FRC #0319 (Big Bad Bob)
Re: TalonSRX invert?
I wouldn't recommend inverting the speed controllers. Just make sure your math takes into account the the fact that your right motors need to rotate in the opposite direction and invert the signal you're sending it.
LeftMotor.set(1)
RightMotor.set(-1)
Unread 05-02-2015, 10:41
I think you're looking for the setInvertedMotor() function. It works with any Robot Drive object regardless of what kind of speed controller you have on your drivebase.
Unread 05-02-2015, 16:29
FRC2501's Avatar
The SetInvertedMotor() function seems to be broken to me, it doesn't like either
driveSystem.SetInvertedMotor(kFrontRightMotor, true);
or
driveSystem.SetInvertedMotor(rightFrontDriveTalon, true);
Unread 05-02-2015, 16:45
or
Lowercase "s"? setInvertedMotor
Unread 05-02-2015, 17:07
FRC2501's Avatar
I looked in the RobotDrive.h and it is a capital S, the error I get is that it isn't a Motor Type
Unread 05-02-2015, 17:25
baumgartensam's Avatar
baumgartensam baumgartensam is offline
AKA: Sam Baumgarten
FRC #0751 (Barn2Robotics)
baumgartensam will become famous soon enough
A number of the method names are capitalized. It drives me crazy (pun intended) as the Java naming convention is a lowercased first letter and then the rest of the word is camel cased. The CANTalonSRX class has a few of these incorrectly named methods as well but it's a fairly minor issue in the scheme of things.
Unread 05-02-2015, 18:03
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
or
Unless you have using statements, I believe you need to qualify the constant names:
driveSystem.SetInvertedMotor(RobotDrive::kFrontRightMotor, true);
FRC 766, 2015-, Mentor
Unread 05-02-2015, 18:26
FRC2501's Avatar
Thanks! It now works
