Go to Post "If I had a nickel for every time our robot actually worked, I'd have one whole nickel. It was fail. Epic fail." - lol, a team at the NYC FTC tourny - Akash Rastogi [more]
Unread 05-02-2015, 16:30
JODawgma JODawgma is offline
FRC #1712
JODawgma is an unknown quantity at this point
Temperature for Gyroscope
Our gyroscope keeps becoming overheated seconds after turning it on, and we believe this is causing it to drift. We think that coding it to adjust for any drifting due to temperature change will fix this issue. We know that there is a specific algorithm that does this for us, and we were wondering if someone could give us the algorithm and/or convert it to LabView code for us to use.
Thanks.
Unread 05-02-2015, 16:33
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Re: Temperature for Gyroscope
Would it be a better idea to figure out why it is overheating, and then prevent that from happening?
We have never had an issue with a gyroscope overheating. That doesn't sound like normal behavior.
1771- Programmer, Captain, Drive Team (2009-2012)
4509- Mentor (2013-2015)
1771- Mentor (2015)
Unread 05-02-2015, 16:42
AustinH's Avatar
AustinH AustinH is offline
FRC #4918 (The Roboctopi)
AustinH is a splendid one to beholdAustinH is a splendid one to beholdAustinH is a splendid one to beholdAustinH is a splendid one to beholdAustinH is a splendid one to beholdAustinH is a splendid one to behold
Relevant: http://xkcd.com/1172/
On a serious note, are you able to send any photos of your gyroscope mount and the proximity to any heat sources?
3826: 2013 Seattle Regional Industrial Design Award & Semi-Finalists
4918: 2014 PNW Glacier Peak District Event Rookie Inspiration Award & Quarter-Finalists, 2014 PNW Mount Vernon District Event Highest Rookie Seed Award, Rookie All Star & Semi-Finalists, 2015 PNW West Valley District Event Engineering Excellence Award & Semi-Finalists, 2015 PNW Mount Vernon District Event Semi-Finalists
Visit us on the web at www.team4918.org
Unread 05-02-2015, 16:43
juchong's Avatar
juchong juchong is offline
Electrical Engineer
AKA: Juan Chong
FRC #2655 (Flying Platypi)
juchong is a jewel in the roughjuchong is a jewel in the roughjuchong is a jewel in the rough
Thanks.
Your Gyro shouldn't be overheating.. Which one are you using? That might help narrow down what might be wrong with it.
Teams I've worked with:My Website: http://www.juanjchong.com/
What I do: Analog Devices iSensor Product Engineer
Unread 05-02-2015, 17:06
FRC #1712
Rephrasing the question: Our gyroscope is drifting and we thought that it might be caused by overheating. We would like to know either why it is overheating or what other causes this might have. If possible, could you also include any algorithms that might helps us with this problem?
ID:	18162  Click image for larger version
ID:	18163  Click image for larger version
ID:	18164  Click image for larger version
Unread 05-02-2015, 17:13
baumgartensam's Avatar
baumgartensam baumgartensam is offline
AKA: Sam Baumgarten
FRC #0751 (Barn2Robotics)
baumgartensam will become famous soon enough
Are you using just a gyro or also an accelerometer and then filtering the data? Drift is common if you are only using a gyro.
Unread 05-02-2015, 17:16
FRC #1712
We only use a gyro.
Unread 05-02-2015, 17:17
AKA: Sam Baumgarten
If you only use a gyro, you can get quite a bit of drift. Gyros work well with low rates of change and accelerometers work well with high rates to change. If you use both, you can get a good number. To do this filtering and combination, there are a number of algorithms. A Kalman filter may be overkill but it will get the job done. Something a bit simpler would be a complimentary filter.
Here are some references to help you out:
Kalman Filter:
http://www.instructables.com/id/Guid...Arduino-inclu/
http://math.stackexchange.com/questi...-accelerometer
http://blog.tkjelectronics.dk/2011/0...h-the-arduino/
Complimentary Filter:
http://www.hobbytronics.co.uk/accelerometer-gyro
http://www.academia.edu/6261055/Comp..._and_Gyroscope
http://www.pieter-jan.com/node/11
Unread 05-02-2015, 17:19
AKA: Sam Baumgarten
Also look at IMUs such as the nav6 and navX. They handle all the filtering for you which may be better if you don't have much experience with filtering. There's also lots of sample code for the RoboRIO.
Nav6: http://www.kauailabs.com/store/index...&product_id=50
NavX: http://www.kauailabs.com/store/index...&product_id=56
Unread 05-02-2015, 17:39
bijan311 bijan311 is offline
FRC #1714
bijan311 is an unknown quantity at this point
Do the other analog inputs on the roboRio have something plugged into them?
Earlier this season my team had a similar issue where the gyro would drift steadily when the robot was stationary and would jump 10-20 degrees whenever we drove the robot quickly. At first, we set a deadband on the gyro in the code, which helped, but did not fully resolve the issue. We then printed the values of the other analog inputs on SmartDashboard and found that when we drove the robot, those values would oscillate wildly, which we assumed made noise one the gyro's signal. To stop this, we plugged in jumper wires going from the ground to the signal of each unused analog input port to keep them at a constant value, and that fixed the drift for us.
Unread 05-02-2015, 21:57
dawonn's Avatar
dawonn dawonn is offline
AKA: Dereck
FRC #2586 (Calumet Copperbots)
dawonn is an unknown quantity at this point
If you google the data sheet for your gyro, it will tell you how much drift can be caused by temperature. They usually have a graph that let's you see the bias vs temperature which is usually a linear relationship.
An accelerometer will only help fix the drift in the roll and pitch angles, which are probably not helpful for you in FRC.
There are some filters which continuously estimate the bias though. One way you could do this is to apply a high pass filter that would filter out the bias. This will not solve all of your problems but may help some.
Your best bet is to try and think of a way to avoid relying on the heading for long periods of time.
Unread 05-02-2015, 22:21
Owen Busler's Avatar
Owen Busler Owen Busler is offline
Build Captain
FRC #0303 (Test Team)
Owen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant future
On my arduino i accidentally wired 5v to ground and ground to 5v on an ultrasonic sensor and it got really hot X_X oops. I hope that isnt your problem.
Unread 06-02-2015, 00:14
AKA: Matt B
FRC #1771 (1771)
I doubt that's their problem, because if they did wire it backwards, I don't think you would be able to read the gyro data for very long, if at all.
Sorry to hear about your ultrasonic sensor though. Did it survive or is it toasted?
1771- Mentor (2015)
