Go to Post FIRST is an opportunity for me to tackle problems that have long been solved. - Madison [more]
Unread 05-02-2015, 16:33
RoboBucs RoboBucs is offline
FRC #5005
RoboBucs is an unknown quantity at this point
Power Distribution Board
Has anyone experienced problems with the 2015 Power Distribution Board? We have just now experienced 2 of the pairs of positive and negative ports not sending out any power. I'v tried it with different breakers, wires, and controllers that were all confirmed working. Is this something that can be fixed or will we have to get a new one?
Unread 05-02-2015, 16:36
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Re: Power Distribution Board
Are the ports outputting ANY voltage? Test with a multimeter.
Are the 2 ports next to each other? Are they the 40A or 20A ports? Are there any metal shavings that could be shorting something out?
1771- Programmer, Captain, Drive Team (2009-2012)
4509- Mentor (2013-2015)
1771- Mentor (2015)
Unread 05-02-2015, 16:53
FRC #5005
We currently don't have a volt meter so we tried shorting the wires and there was no spark at all. They aren't next to each other either, they are on opposites sides and a couple down from each other. They are 40A and we've blown into them and don't see any metal shavings in them at all.
Unread 05-02-2015, 16:57
FRC #5005
We did just try it with a volt meter and no power was coming from it
Unread 05-02-2015, 17:03
AKA: Matt B
FRC #1771 (1771)
Just to be sure: You did have a fuse in the correct place, right?
Also, I would recommend NOT intentionally shorting the wires together, just for future reference.
As for the problem at hand: Did this suddenly happen or has it been a problem all season? If it did just happen, what was previously connected to it?
And all the other ports are working fine? Does the roboRIO Web interface show any errors on the PDP?
1771- Mentor (2015)
Unread 05-02-2015, 17:16
FRC #5005
We had breakers in all of the slots so I know there was one there. This problem just recently occurred, it has had a motor controller hooked up to it all season and we recently took them all out. The wires may have been shorted when we took them out, would that have to do with it?
What do you mean by the "RoboRio Web Interface"? Is that the driver station in Labview?
Unread 05-02-2015, 17:19
The PDP (note: Power Distribution Panel) is built with seriously hefty copper traces. If part of it is not working when a breaker is correctly installed, it's probably physically broken such that I would expect the damage to be obvious.
Can you take a photo of it and show us what it looks like when it isn't providing power on the Wago terminals you expect it to? Give us a good look at the wires and the circuit breaker.
Unread 05-02-2015, 17:41
FRC #5005
Its the one on the right that isn't working. the left one is.
Unread 05-02-2015, 18:02
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
Most common symptom I've seen is releasing the WAGO connector in such a way where it pinches the insulation instead of the copper.
Try the attached test procedure to see what the problem is.
Name:	PDP check.png
Unread 05-02-2015, 18:07
Volunteer, WPILib Contributor
no team (Waiting for 2021)
Why do you guys have Red and Black inverted on that 30A breaker. Could that cause the problem?
Team 4488 - Mentor 2013-2016
Unread 05-02-2015, 18:26
FRC #5005
I did all the voltage testing, and there was no voltage coming from the wago connectors. I also didn't experience any voltage through the breakers but it was the same for all the breakers that were working too.
Concerning the black and red switched wires, some of our guys had to solder the wires and they soldered the red to the ground port and the black to the positive port because it wasn't labeled on the camera they were soldering it to, so the red is actually the ground and the black is the positive.
Unread 05-02-2015, 18:32
ozrien's Avatar
Omar Zrien
AKA: Omar
... I also didn't experience any voltage through the breakers but it was the same for all the breakers that were working too.
This does not help us deduce what is going on. Did you make contact with the exposed metal portion of the breaker (please see P1 and P2 in the pic to find the exposed metal).
Unread 05-02-2015, 18:41
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Try swapping the breakers in #6 and #7.
Power on the robot, but don't try to do anything.
See if you get power in #6, and not in #7. It could be a bad breaker.
Put the good 20 amp breaker back into #7.
BTW: what camera are you using? Most are 5 volts, and can't be powered directly from the PDB.
You will have to fix the wire coloring before a competition. Robot Inspectors will ding you for that.
Unread 05-02-2015, 18:57
FRC #5005
Okay, i corrected that error. I am not getting any voltage from the non working slot through the breaker and I am through the working slots and their corresponding breakers
Unread 05-02-2015, 19:17
ozrien's Avatar
Omar Zrien
AKA: Omar
You're not getting 12V at both P1 and P2? Is the meter's ground probe connected directly to battery's ground (step3)? Please be as specific as possible.
