Go to Post Once again, the GDC is pure evil. (Dave, Aidan, and Bill get the "pure evil genius" rating which is slightly worse.) - EricH [more]
Thread Tools Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Unread 04-02-2015, 16:37
cmastudios's Avatar
cmastudios cmastudios is offline
AKA: Connor Monahan
FRC #1706 (Ratchet Rockers)
cmastudios is an unknown quantity at this point
1706 Vision Solution: Tracking totes in depth-map, color, and infrared
The Ratchet Rockers team 1706 has been hard at work this build season to bring you the public release of our vision solution.
INTRODUCTORY VIDEO: http://youtu.be/HYWgS2M8Zy4
Source code at: https://rr1706.github.io/vision2015/
Specifications:
- C++ code
- Intended for a coprocessor (ODROID / Raspberry Pi)
- Uses the OpenCV library
- Written on Ubuntu 14.04 linux
- Designed for Xbox 360 Kinect (could be used by any color, IR, or depth-map camera)
The program has the ability to track the field totes in three different modes: depth map, infrared light, and color. The use of a depth map to aid in tracking was used by the team for the first time in a competition. It allows the retrieval of more features
Explanation of Depth logic: https://github.com/rr1706/vision2015...th-Explanation
Explanation of IR logic: https://github.com/rr1706/vision2015...IR-Explanation
A few items still are being worked on: better color thresholds, an edge detector to replace the calibration image, transmitting camera images, multithreading, and so on.
To get the program working, you will need:
- Ubuntu 14.04 linux
- Xbox 360 kinect
- C++ knowledge
Steps to get the program working:
1. Install the dependencies: sudo apt-get install build-essential libfreenect-dev qtcreator libopencv-dev
2. Clone the repository to your computer.
3. Open the vision2015.pro file with Qt Creator.
4. Configure Qt Creator to build the project for Desktop.
5. Visit the source code file demo.cpp in the Qt Creator sidebar to change your basic options.
The main function near the bottom of the file selects which mode to use. Select color for basic color tracking, or any other function available in the program by changing the line to call a function available. Check tracker.hpp for the classes that contain the various vision tracker programs. You may need to change the thresholding values for your current lighting conditions (your environment or day/night cycle). You can use my program multithresh (https://github.com/rr1706/multithresh) to select proper threshold values (stored in tracker.hpp).
Unread 04-02-2015, 16:49
AustinH's Avatar
AustinH AustinH is offline
FRC #4918 (The Roboctopi)
AustinH is a splendid one to beholdAustinH is a splendid one to beholdAustinH is a splendid one to beholdAustinH is a splendid one to beholdAustinH is a splendid one to beholdAustinH is a splendid one to behold
Re: 1706 Vision Solution: Tracking totes in depth-map, color, and infrared
Fantastic work. We'll be sure to give this a try.
Have you tried it on a Jetson by chance?
3826: 2013 Seattle Regional Industrial Design Award & Semi-Finalists
4918: 2014 PNW Glacier Peak District Event Rookie Inspiration Award & Quarter-Finalists, 2014 PNW Mount Vernon District Event Highest Rookie Seed Award, Rookie All Star & Semi-Finalists, 2015 PNW West Valley District Event Engineering Excellence Award & Semi-Finalists, 2015 PNW Mount Vernon District Event Semi-Finalists
Visit us on the web at www.team4918.org
Unread 04-02-2015, 16:59
cmastudios's Avatar
AKA: Connor Monahan
Haven't tried to get it running on anything but my laptop and an ODROID-XU. We were thinking of looking into getting one to potentially improve the performance in comparison to the ODROID but haven't focused on it yet. We may.
Unread 05-02-2015, 12:24
Fauge7 Fauge7 is offline
Head programmer
FRC #3019 (firebird robotics)
Fauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to all
have you thought about using the i2c communication to the roborio from the odroid c1 instead of sending a udp message?
Unread 05-02-2015, 13:41
Cinnamon Toast's Avatar
Cinnamon Toast Cinnamon Toast is offline
FRC #3641 (The Flying Toasters)
Cinnamon Toast is an unknown quantity at this point
This looks exceptional. I have access to a Jetson, and once I get some time, I'll see if I can get it working on the system. I'll definitely reply back with performance stats.
Unread 05-02-2015, 17:33
baumgartensam's Avatar
baumgartensam baumgartensam is offline
AKA: Sam Baumgarten
FRC #0751 (Barn2Robotics)
baumgartensam will become famous soon enough
If I get a chance I'll see if I can get a GPU optimized version working to take full advantage of the Jetson's GPU.
Unread 07-02-2015, 18:31
cameronr2980 cameronr2980 is offline
FRC #2980
cameronr2980 is an unknown quantity at this point
Hello,
I have been trying to get this program running on an nvidia Jetson TK1 for the past few hours. I can't seem to get some of the dependencies to install. apt comes back with an error saying that every package except for build-essential cannot be located. "Unable to locate package x." I have looked around on the internet for a solution and tried a few but none of them have worked. This may be more of a linux question but does anyone see an easy solution to this? I'm thinking about reflashing linux and trying again.
Unread 07-02-2015, 20:15
faust1706's Avatar
faust1706 faust1706 is offline
faust1706 is infamous around these partsfaust1706 is infamous around these parts
did you try sudo apt-get install libopencv-dev?
"You're a gentleman," they used to say to him. "You shouldn't have gone murdering people with a hatchet; that's no occupation for a gentleman."
Unread 07-02-2015, 21:21
yash101 yash101 is offline
AKA: null
Originally Posted by cameronr2980 View Post
Hello,
Try:
sudo apt-get update
Apt-get gives those errors all the time when the repos aren't up-to-date. What is the command you are running?
Also, I suggest that you compile OpenCV manually for the Jetson because it supports a crapload more of optimizations than other boards. I don't have a Jetson, but I'm sure that it uses the same repository as the other boards, like the ODROID.
The Jetson has CUDA support, one thing that should used to it's max for it's glory! It'll make your code run just a lot faster!
Unread 08-02-2015, 01:27
faust1706's Avatar
I would love to see the performance of our code on the Jetson. Please someone deliver. I'm willing to thread it and optimize it if someone wants to bench mark it for me.
Unread 08-02-2015, 13:39
FRC #2980
Originally Posted by yash101 View Post
Try:
sudo apt-get update
I've tried apt-get update and apt-get upgrade, both completed just fine and I still had the same error. I get the error from running:
sudo apt-get install libavcodec-dev
I get the error for a couple more packages too, that is just an example. I think that all the problems i'm having are with open CV so i think i will reflash ubuntu and try again, this time compiling openCV myself.
Unread 08-02-2015, 14:35
AKA: null
Please try running apt-cache search libavcodec > out.txt and upload out.txt to this forum. That'll search through the repo and possibly output a ton of text! If the package is found, you're golden.
Unread 08-02-2015, 18:35
cmastudios's Avatar
AKA: Connor Monahan
It could be a factor of the repositories you have enabled... check /etc/apt/sources.list
Unread 08-02-2015, 18:57
FRC #2980
That returns:
"libavcodec-dev - Development files for libavcodec"
as well as several more lines like it describing other packages. I'm really confused now because this means that it found the package, right? But when I use apt-get to try and install it it says it can't be found.
It might be because I'm on the school network now think of it. I'll keep trying.
Unread 08-02-2015, 19:03
FRC #2980
Now it found every one of the dependencies no problem. No idea what was wrong but thank you all for the help.
