Go to Post If this was really about changing the culture, FIRST would be on Will.I.Am's website. - Meredith Novak [more]
Unread 05-02-2015, 19:38
EDesbiens's Avatar
EDesbiens EDesbiens is offline
Passionate crackpot
AKA: Étienne Desbiens
FRC #5859 (i)
EDesbiens is a glorious beacon of lightEDesbiens is a glorious beacon of lightEDesbiens is a glorious beacon of lightEDesbiens is a glorious beacon of lightEDesbiens is a glorious beacon of lightEDesbiens is a glorious beacon of light
Speaker and/or iPad in operator console
Hey! I wondered if it was ok to hav e speakers in our operator console... We would use them during matches to signal errors... I looked in the game manual and didn't really found and answer...
I also wondered if we could have an iPad on the operator console. We would disable internet and bluetooth and it would only be used to discuss strategy and scouting...
I hope you guys know the answer!
Unread 05-02-2015, 19:49
Re: Speaker and/or iPad in operator console
I can't find anything either, but you may want to consider using a visual cue instead. I hear it gets pretty LOUD down there.
You don't have to have it on the console--this would fall under T21, so in fact you don't want it on the console (see T21.E.1). (Matter of fact... you REALLY DON'T want it on the console, as your coach would most likely be the one using it, and that would end up being a disablement of your robot under G32.) Make sure you follow all items in T21E, though--particularly 4, 5, and 6.
Unread 05-02-2015, 19:54
EDesbiens's Avatar
Passionate crackpot
FRC #5859 (i)
For the speakers, I know how it can be loud on the field but, last year, one of our drivers was supposed to react to a big signal light on our computer screen (big means it was half of the screen) and he was too focused on the field to see the entire screen turning red...
For the iPad, do you think it would be ok to put a kind of case on the driver station to attach it there and remove it when we arrive at a match?
Unread 05-02-2015, 19:58
Sperkowsky's Avatar
Sperkowsky Sperkowsky is offline
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
I don't see a problem with the iPad. The speakers though could be an issue. I know there is a rule no speakers on robot carts so it may apply
Unread 05-02-2015, 20:09
That would be fine, I'm sure. As long as it's in the hands of whoever's supposed to be using it before automode starts, you should be A-OK.
I might recommend some Velcro on the iPad's own case and some more on the operator console for transport. Just to keep it mostly in place and all.
Unread 05-02-2015, 20:36
Whippet's Avatar
Whippet Whippet is offline
MIT Class of 2020
AKA: Luis Trueba
FRC #4301 (New Tech Narcissists)
Whippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond repute
Send a message via Yahoo to Whippet
Instead of a sound cue, what about having an LED on your driver's safety glasses that turns on and off (Via the Cypress board, IIRC) to signal the information you want to convey? I've heard of several teams who have used it successfully.
2010: FRC 3043, Build Assistant
2011: FRC 3043, Head of Minibot subteam; FLL 12762, Team Captain
2012: FRC 3043, Electrical; FLL 12762, Team Captain; FTC 5670, Team Captain
2013: FRC 4301, Electrical, Team Co-Captain
2014: FRC 4301, Electrical/Programming, Team Co-Captain
2015: FRC 4301, Electrical/Programming, Team Captain
2016: FRC 4301, Chief Technical Officer; FTC 10860, 10861, and 11004: Mentor. Winner, Hub City Regional (3310 & 4063)
Unread 05-02-2015, 20:50
EDesbiens's Avatar
Passionate crackpot
FRC #5859 (i)
Wow! That's a great idea! I think i'll try to work on this one
Unread 05-02-2015, 22:23
We played around with game controller rumble today. That's probably going to be our mechanism for alerting the driver and operator to things. The other possibility is to use lights on the robot itself.
Unread 06-02-2015, 07:13
EDesbiens's Avatar
Passionate crackpot
FRC #5859 (i)
We looked at that too... The only thing is that the controllers we normally use (logitech, I don't know the model) do not have vibration... But yeah, that's another greath idea
