Go to Post There's 2 things that are really hard in CS - naming things, cache invalidation, and off by one errors. - Andrew Schreiber [more]
Unread 05-02-2015, 20:52
16flippinb 16flippinb is offline
FRC #5216 (Team 5216 "The E-Ville Empire")
16flippinb is an unknown quantity at this point
Winch problem
Hello all, we are having a problem with our winch not holding tension. When we stop pulling the boxes off of the ground, and reach the desired height, the winch begins to unwind very slowly. The more totes and cans we have, the faster it unwinds, and vice versa. We are using a CIM motor to a Vexpro base versaplanetary gearbox with a 1/2" HEX output. The gearbox is attached to a flywheel that winds and unwinds the winch. Is this a problem with our programming, the gearbox, or something else? Any advice would help! Thanks -Team 5216
Unread 05-02-2015, 20:56
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Re: Winch problem
When you tell a motor to stop, all it does is supply 0V across the leads. This means that the motor can backdrive, which is what you're seeing. You have two options... Tell the motor to go "up" very slowly in order to hold its position, or implement some sort of mechanical brake. Keep in mind, stalling a motor (telling it to move while not letting it move) will cause heat build up. Depending on the situation, it's possible to burn out a motor by stalling it too long.
2016: Lake Superior WFFA
Unread 05-02-2015, 20:58
DarkRune DarkRune is offline
AKA: Dylan Baker-Flynn
FRC #4159 (CardinalBotics)
Team Role: Driver
DarkRune is a jewel in the roughDarkRune is a jewel in the roughDarkRune is a jewel in the rough
Re: Winch problem
^This guy beat me to it, but yeah sounds like the motor is back driving, that can be fixed with a small upwards rotation, or with a clamping break like on a bike. What's the gear ratio in the versaplanetary?
Unread 05-02-2015, 21:12
Re: Winch problem
the gear ratio is 70:1
Unread 05-02-2015, 21:18
Anthony Galea's Avatar
Anthony Galea Anthony Galea is offline
Formerly known as 3175student17
Anthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant future
Re: Winch problem
Would another option be to have the motor move forward then backward in small, short, yet equal amounts?
2013-2016: FRC 3175 Knight Vision, student
2014 Center Line District Finalists with 815 and 280
2016 Woodhaven District Winners with 3604 and 6116
2017-?: Rose-Hulman Institute of Technology
Unread 05-02-2015, 21:35
Mike Marandola Mike Marandola is offline
Lead Bumper Mentor
AKA: Mike Marandola
FRC #0316 (Lunatecs)
Mike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond repute
Re: Winch problem
Depending on the weight and friction in the system, the amounts may not be able to be equal. It might just drop slower.
For OP, here is some more information about mechanical brakes:
http://www.chiefdelphi.com/forums/sh...d.php?t=133272
http://www.chiefdelphi.com/forums/sh...d.php?t=132825
http://www.chiefdelphi.com/forums/sh...d.php?t=132158
2015 - Pioneer Valley District Finalists/Upper Darby District Finalists/MAR District Championship #1 Seed and Winners with 225 and 203
2014 - Lenape Seneca District Winners/Chestnut Hill District Winners
2013 - Lenape Seneca District Winners/Chestnut Hill District Finalists
2011 - Philadelphia Regional Finalists
2009 - Finger Lakes Regional Finalists
Unread 05-02-2015, 21:36
Re: Winch problem
You can pulse the motor like that, yes. Depending on the deisgn and what you need it to do, such a motion may not be practical. Implementing a mechanical brake is a much better Design, IMO.
Unread 05-02-2015, 22:04
jimwick's Avatar
jimwick jimwick is offline
jim wick
FRC #0885 (the Green Team)
jimwick is a glorious beacon of lightjimwick is a glorious beacon of lightjimwick is a glorious beacon of lightjimwick is a glorious beacon of lightjimwick is a glorious beacon of light
Re: Winch problem
Do you have your motor controller set to "brake" instead of "coast?" That can help some.
We have the same problem and are planning to give the CIM a little voltage to hold the system in place. That will eventually burn out the CIM, but they are pretty rugged and will probably survive. We plan to bring some extra CIMS!
Unread 05-02-2015, 22:14
Chris is me's Avatar
AKA: Pinecone
Re: Winch problem
It wouldn't be much better, really, especially for CIM style motors.
You can safely stall a CIM style motor at a fairly low power percentage for a decent amount of time. I wouldn't worry too much about it. Just add the feed-forward.
Unread 05-02-2015, 22:19
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Re: Winch problem
Attached is an image of our mechanical lock (disk brake) to alleviate this issue.
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 06-02-2015, 20:59
Chinske4296 Chinske4296 is offline
FRC #4296
Chinske4296 is an unknown quantity at this point
Dry an anti back drive system, via ratchets or some other means. Last year we used a ball shifter, instead of a second stage we took the gears out acting as a neutral gear. I see no reason you couldn't use a similar function with a ratchet.
Unread 06-02-2015, 21:00
FRC #4296
We had a ratchet on the shaft allowing the ratchet to turn with out moving the shafts connected to the motor, thus preventing backdrive.
Unread 06-02-2015, 21:41
rookierunner's Avatar
rookierunner rookierunner is offline
FLL / FRC Mentor
AKA: Tom L.
FRC #2340 (Xcentrics)
rookierunner has a spectacular aura aboutrookierunner has a spectacular aura about
Although the software fix described above will work and cims are very durable... there is another non-software option. As worm gear will not allow the motor to back drive. I wouldn't recommend a window motor for the task, but they are an example of a gearbox with a worm gear.
Good luck to you this season.
Unread 06-02-2015, 22:36
richwong richwong is offline
None #1701 (Robocubs)
richwong is an unknown quantity at this point
Re: Winch problem
What do you have "pulling" the brake cable?
Unread 07-02-2015, 07:26
GortGortGort's Avatar
GortGortGort GortGortGort is offline
AKA: Lee Cole - Mentor
FRC #5040 (The BoltBots)
GortGortGort has a spectacular aura aboutGortGortGort has a spectacular aura about
Re: Winch problem
One solution not mentioned is the use of a two drum winch design with one cable from one drum pulls up while the other cable pulls down .
A spring or latex tubing attached to your lift with continuous upward force properly adjusted to your lifting weight will work fine to control motor/ gearbox back-drive. It really makes your winch work to pull the lifting arm down first
and less force to pull weight up.
http://info.vulcanspring.com/first-robotics-competition
Check out voucher from Vulcan Spring . You could add this quickly to your bots
lift to stop the back-drive with out changing your design as long as your winch
is not relying on a gravity return lift arm . Are you using a single cable drum ? Photo of your winch might be useful for us to help you solve the problem.
http://www.chiefdelphi.com/media/photos/41279?
