Go to Post Just to be clear, NOTHING anyone says here is a confirmation. The ONLY source for official answers to questions like this is the FIRST Q&A system. - dlavery [more]
Unread 06-02-2015, 00:17
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Re: Jittery Motor
Originally Posted by DarkRune View Post
What's the code you are running on it? Something I've noticed with code is that it often oscillates between forward and backwards.
What kind of code are you using that's doing that?
The code really shouldn't cause a motor to oscillate between forward and backwards too often, unless it is a PID loop trying to get to the exact position... (Or if your driver is rocking the robot back and forth.)
1771- Programmer, Captain, Drive Team (2009-2012)
4509- Mentor (2013-2015)
1771- Mentor (2015)
Unread 06-02-2015, 14:01
topgun's Avatar
topgun topgun is offline
FRC #2846 (FireBears)
topgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant future
Re: Jittery Motor
Check the dowel pins used to hold the planet gears. Each of our 7:1s had a dowel pin that stuck just slightly out of the backside.
-T
