Go to Post We had an over all losing record this year. When I look at kid's faces, they don't give a rip about that. I see excitement about the next event and talking about improvements for next year. Winning is nice, but that is not the reason I do what I do. - wilsonmw04 [more]
Unread 06-02-2015, 00:26
wt200999's Avatar
wt200999 wt200999 is online now
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
Re: Temperature for Gyroscope
Originally Posted by nighterfighter View Post
I doubt that's their problem, because if they did wire it backwards, I don't think you would be able to read the gyro data for very long, if at all.
Sorry to hear about your ultrasonic sensor though. Did it survive or is it toasted?
I would say it is possible that if the gyro was damaged, all you get is noise (assuming the sensor is analog) since the roboRIO will read something. And since the roboRIO just integrates this value it would take off and may even look like 'drift' if you assume the gyro is working. This possibility does match the original description, especially since it gets hot 'seconds after turning it on'.
When you say the gyro gets hot, how hot are you talking about?
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
