Go to Post I hate mini-bots. - Gdeaver [more]
Unread 05-02-2015, 13:37
theonlydvr theonlydvr is offline
FRC #4338
theonlydvr is an unknown quantity at this point
Java NIVision imaqSavePattern error
Hey all,
I've been trying to use the NIVision library for vision processing on our robot however I constantly get undefined symbol errors when I try to call certain methods. The major one in question is NIVision.imaqSavePattern. Does anyone know why this happens? I read something about bad java wrappers but could it wasn't very clear.
Thanks for any help,
Evan
Unread 05-02-2015, 15:23
mmaunu's Avatar
mmaunu mmaunu is offline
FRC #2485 (W.A.R. Lords)
mmaunu is a jewel in the roughmmaunu is a jewel in the roughmmaunu is a jewel in the roughmmaunu is a jewel in the rough
Re: Java NIVision imaqSavePattern error
Posting your code (or a sample that produces the error) will help people help you.
2014 Las Vegas (Winners with 987, 2478; Excellence in Engineering)
2014 San Diego (Finalists with 987, 3250; Quality Award)
2013 Inland Empire (Winners with 1538, 968; Excellence in Engineering Award)
2013 San Diego (Finalists with 2984, 4322; Creativity Award)
2012 Las Vegas (Finalists with 2034, 3187; Quality Award)
Unread 05-02-2015, 15:48
FRC #4338
At the moment, I do not have access to the code but in its current form it is built off of the Intermediate Vision sample class with just the added line
    NIVision.imaqSavePattern(frame, "image.jpg");
Unread 05-02-2015, 23:38
Fauge7 Fauge7 is offline
Head programmer
FRC #3019 (firebird robotics)
Fauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to all
I think your code is supposed to be
NIVision.imaqWriteJPEGFile(image, fileName, quality, colorTable);
for saving an image
Unread 06-02-2015, 00:34
mmaunu's Avatar
Have you seen this post?
http://www.chiefdelphi.com/forums/sh...d.php?t=132494
It seems that they did update the NIVision wrappers and this was done to address some of the same issues that you are facing. However, if you have the latest version of the Java API from WPI, you should have the updates that they reference. You can check to see if your libraries are up to date by looking at this page and then checking the version numbers on your Eclipse plugins.
http://wpilib.screenstepslive.com/s/...ware-revisions
Here is a link to the NIVision API (which looks like it should be up to date):
http://first.wpi.edu/FRC/roborio/rel...1NIVision.html
It does not list the method that you are trying to call but it does list the method that Fauge7 referenced...
