Go to Post Actually there are several Wayne Cokeleys circulating around. We cloned him in 2001. This is his evil twin Mordechai responding.....-WC 3 - Wayne C. [more]
Unread 15-01-2002, 00:59
mnkysp6353's Avatar
mnkysp6353 mnkysp6353 is offline
no team (Bagel Bytes)
mnkysp6353 is an unknown quantity at this point
Send a message via AIM to mnkysp6353
AHHH I need help!
Someone came up with a design for a motor mount for the chalupa motor and i cant find it anymore. If you can find it please help me and post the link.
Unread 15-01-2002, 06:42
Mark Jones Mark Jones is offline
Engineer - Team 343 MIM
FRC #0343 (Metal-in-Motion)
Mark Jones will become famous soon enoughMark Jones will become famous soon enough
Send a message via AIM to Mark Jones
chiaphua motor mount
Attached is the pic I downloaded from the post. Is this what you are looking for?
Unread 15-01-2002, 11:37
mnkysp6353's Avatar
yes it is thank you very much. Could you post the link to the post you got this from.
Thanks
Justin
Unread 15-01-2002, 14:29
Here is a photo of a prototype Chiaphua motor mount. The dimensions are pretty simple:
Motor mount screws are 10-32, spaced exactly 2.00" apart
The center "bulge" is .75" in diameter
The centers of each gear (shaft, big gear) is .740" apart.
I mounted the cluster .75" from the center of the motor shaft and there is a bit of play. If/when I do this again, I will split the difference and mount the cluster .745" from the shaft.
This was all determined on my kitchen table with a caliper. I punched out the 1/4" plate with my milling machine (you need at least an accurate XY table) and press fit the 1/4" ground drill rod shaft.
Team #492
Attachment: dscn2581.jpg
Unread 15-01-2002, 17:04
mnkysp6353's Avatar
What did you use to mount the shaft to the plate? (ie bearing or other) Also what is the final rpm coming out of this shaft? Is this close to the drill motors rpm?
Thanks
Justin
Fantasy Football! EddieMcD Chit-Chat 176 30-12-2003 18:30
Help Hax0ring my Honda, please DanL Technical Discussion 25 28-09-2003 00:50
Centered info? Trashed20 CD Forum Support 7 05-09-2002 21:41
Silicon Valley Regional Get Together (ahhh yeah) archiver 2001 0 24-06-2002 02:22
Team Quiz MrsT General Forum 7 02-03-2002 18:54
