| Thread Tools |
Rating:
Display Modes |
#16
Re: Team Update: Drive Team Placement in Playoffs
The static placement of teams based on intra-alliance standing is a boon for logistics at the team, alliance, and field operation levels. Drive teams always know where they are setting up, alliance captains are always at the best station for coordinating, MC and GA always know which team will be the alliance captain by just looking at the field, as will spectators, etc. Here is a thought: if you are an alliance captain, how much stock are you putting into HP placement? Do you want the 2 HP to be next to 2 station, 3 HP next to 3 station, and your HP running some tactical function like the 2011 HP not at the slots? You could even say there might be an opportunity if the 2 and 3 HPs are similar enough to the 1 HP that your 1 HP could be coached up on helping to coordinate 1 Drive Team while 1 Coach operates as a field marshal of sorts, understanding and accepting some obvious tradeoffs with this move. |
#17
You are making a tradeoff if you pull a familiar HP for the purposes of better coordination between teams, and I don't even know if it could be worth it yet. It's just something I'm going to simmer over for a bit. |
#19
This is something that I would like to ask in the Q&A but it also seems inappropriate for Q&A since the rule is incredibly clear. Is there a forum for asking "Why did this rule (about red placing robots on the field before blue) get made when it clearly gives a disadvantage to the higher seeded alliance even though they earned the right to have the advantage?"?
Did they, perhaps, give the advantage to the lower-seeded alliance in an attempt to balance the play? That seems particularly rough in the Finals matches and/or at high levels of play where both sides will be vying for the center containers. Last edited by mmaunu : 05-02-2015 at 13:16. Reason: Added clarity to vague section...I hope |
#21
Beyond the impact at regional events, the implications for Einstein are huge. At least in a subdivision or at a regional, you can plan and prepare for the situations you will be facing when making your selections.
On Einstein, where this rule will have the greatest impact, presumably, the "seeds" will be randomly set, and some divisions will have an inherent advantage, by no doing of their own. I'm not committed to this idea, but one way to at least make it feel more fair would be with a ABBAAB format. It would also save time, since the current way presumably could take up to 6 minutes, since each team needs to set up their robot. |
#22
I'm not sure why these new rules came out in this update?
If anything, why not let teams decide which alliance station they want. Its been done before at offseason events and allows teams to comfortably choose where they want to be, optimizing vantage points for the entire alliance. To some extent it does matter. Some drivers are tall, some short and anyone that has ever coached behind the glass will tell you that the view is much different than for a spectator seeing the whole field. The field isnt symmetrical with respect to each alliance. The only reason I see that red places their bots first, is to level the playing field as others have suggested. Last edited by waialua359 : 05-02-2015 at 14:05. |
#24
I don't think of it as pulling the top down, I think of it as pushing the top and the bottom closer together. (sorry if this is derailing a thread, it's kind of a pet peeve of mine.) |
#25
So if one is uncomfortable with the higher seed "earning" an advantage then why not argue for alternating second placement status during auto set up with each match played?
#27
The Q&A was answered, and confirms this Blue alliance advantage:
I don't think that the draft order completely balances the issue, by the way, but I also don't think that it should balance out perfectly. I believe that the tournament rules should provide incentive to be the first seed. This new rule provides a unique penalty to being first seed; they will never by anything but the red alliance and be at a significant disadvantage in all of the playoffs matches and in the actual finals for an event. This will also play out very strangely on Einstein this year where teams come from different fields; will four alliances will win the lottery and be assigned the color blue? Actually, I am not sure that they have defined the process for picking alliance colors on Einstein...I can't find that information in the manual. Edited to add: I do think that there are a variety of equalization strategies that could also be employed as well (as others have mentioned). Robot placement could alternate from game to game: Red-then-Blue in one game and then Blue-then-Red in the next game. You could also just flip a coin before each match to make the advantage less predetermined or less one-sided. Last edited by mmaunu : 06-02-2015 at 12:38. Reason: Added "Edited to add" section |
