Go to Post Isn't FIRST robotics the answer to life, the universe, and everything? - weberr [more]
Unread 06-02-2015, 14:13
alinas1 alinas1 is offline
FRC #2230
alinas1 is an unknown quantity at this point
Cordless drills
If you don't give any voltage to a cordless drill, it won't turn. No matter how much you will try to turn it (with your hand) you won't succeed. How and why does this happen?
Unread 06-02-2015, 14:16
Addison4300's Avatar
Addison4300 Addison4300 is offline
FRC is love, FRC is life
AKA: Addison
FRC #4300 (The Lion Kings)
Addison4300 is on a distinguished road
Re: Cordless drills
The drill is spun by electro-magnets and locks in place when not given any power if I am correct.
Unread 06-02-2015, 14:21
baumgartensam's Avatar
baumgartensam baumgartensam is offline
AKA: Sam Baumgarten
FRC #0751 (Barn2Robotics)
baumgartensam will become famous soon enough
Re: Cordless drills
My understanding is that many have a mechanical brake that engages when the drill is stopped. Some newer drills also have electric brakes that slow down the chuck using the energy from the deceleration of the chuck (I forget exactly how they work). The E-brakes don't continue braking after the drill stops where as the mechanical brakes do. Look on youtube for some videos with people disassembling drills.
Unread 06-02-2015, 14:30
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Cordless drills
Here's an often-cited paper on converting a DeWalt clutch for FRC purposes.
Unread 06-02-2015, 14:31
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Re: Cordless drills
Cordless drills have anti-backdrive pins built into them. They are small metal cylinders that shift when the drill head attempts to rotate when the motor is not rotating.
In fact, the window motors you have use a similar system:
http://www.chiefdelphi.com/media/papers/download/3449
Page 6 of the nothing-but-dewalts whitepaper linked above has a picture showing the anti-backdrive pins.
