Go to Post FIRST's awesomeness cannot be described in numbers. - Shinglei [more]
Unread 06-02-2015, 14:41
Skyehawk's Avatar
Skyehawk Skyehawk is online now
Nuts N' Bolts
AKA: Skye Leake
FRC #0876 (Thunder Robotics)
Skyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to all
Re: Program a dead zone?
Originally Posted by Alan Anderson View Post
This is the block diagram of the Deadband.vi we use. It subtracts the deadband size from the input value. If the result is less than zero it keeps it at zero. Other code can use the "In Deadband?" output to do things like maintain heading or activate a brake.
quick question: How do you export labview code so you can just drop it in?
