Go to Post What isn't fun about watching a robot hang tubes? I love watching my team do it! - Michael Corsetto [more]
Unread 31-01-2015, 21:47
Team3220's Avatar
Team3220 Team3220 is offline
Mechanic of Mayhem
FRC #3220 (Mechanics of Mayhem)
Team3220 is an unknown quantity at this point
Relay Problems
We are having some trouble coding some relays. We want to use window motors attached to spike relays to raise and lower an arm (kinda like the front of a tractor) to lift the totes for this year"s game. We need help coding the relays and motors, and assigning buttons to stuff. Do you need to use some comparison code or something? We are total rookies, and some help or links to other forum posts with the same issue would be greatly appreciated. I can post pictures of stuff we have tried / are trying, if you guys think it will help.
Unread 31-01-2015, 22:00
ATannahill ATannahill is offline
AKA: Alex Tannahill
Re: Relay Problems
Can you tell us more what how you expect this to be controlled?
Will you have two positions (up and down)? three? Or do you want to be able to stop anywhere in the path?
Do you want a button that drives it up and one that drives it down? Do you want a button that sends it to the top most position and one for the bottom position?
How will you know when it is at the end of the movement? are the limit switches?
Unread 31-01-2015, 22:23
Team3220's Avatar
Mechanic of Mayhem
Re: Relay Problems
We're trying to keep it simple- hold a button to raise, hold a button to lower. I guess that would be 2 positions. We want it to stop whenever the driver stops pressing the button. The arm is powered by a winch/pulley type of deal, so as of right now it's up to our driver to not raise the arm too high and bog down the motor (unless we can figure out a way to limit the motor's rotation. We plan on doing stuff like that once we have the main robot working how we like it.)
Unread 01-02-2015, 22:13
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
Re: Relay Problems
What language? Labview, C++, or java?
Brian K
Team 1225 Robotics Mentor
Unread 01-02-2015, 22:54
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Relay Problems
I'd presume LabView, since it's on the LabView forum.
Unread 01-02-2015, 23:08
Re: Relay Problems
This thread probably has what you want. See post #6 for sample code.
Unread 06-02-2015, 14:56
Team3220's Avatar
Mechanic of Mayhem
Re: Relay Problems
Here's our code- it's giving us an error in TeleOp saying that the Relay DevRef needs to be wired. Also, we fixed the Set/Get issue
Name:	Relay Code 2.PNG
Unread 06-02-2015, 15:23
Re: Relay Problems
You see your Relay RefNum Get? Yeah, what you have there is actually a Relay RefNum Set. Replace it with the right one and that error will be gone.
Unread 06-02-2015, 17:54
Team3220's Avatar
Mechanic of Mayhem
Re: Relay Problems
We got it mostly fixed. Still an error on the second comparison. I'll post a picture when I get home.
