Go to Post The teams who have the best chance at success are the ones who know where they can save time and money on machining by using or using part of some premade equivalent. - Bill Gold [more]
Thread Tools Rating: Thread Rating: 13 votes, 5.00 average. Display Modes
Unread 06-02-2015, 17:08
chraezyaz chraezyaz is offline
FRC #3700
chraezyaz is an unknown quantity at this point
problem with running labview simulator
I was hoping if anyone has any advice on resolving the following problem when we try to run our robot simulator.
Error -310194 occurred at NI_Robotics_Simulator.lvlib:ODESimulator_Motor.lvc lass:Get Motor Index By ID.vi->NI_Robotics_Simulator.lvlib:Get Actuator By ID.vi->DC Motor Controller Simulator.lvclass:Initialize (Simulator).vi->WPI_MotorControlOpen&ConfigurePWM.vi->WPI_MotorControlOpen Talon.vi->WPI_RobotDriveOpen2MotorWithTalon.vi->Begin.vi->Robot Main.vi
Possible reason(s):
LabVIEW Robotics: (Hex 0xFFFB444E) The actuator ID you specified does not correspond to any actuators associated with the robot ID in the manifest file for this simulation instance.
Thank you for the help!
Unread 22-02-2016, 23:26
apm4242 apm4242 is online now
FRC #4242
apm4242 has a brilliant futureapm4242 has a brilliant futureapm4242 has a brilliant futureapm4242 has a brilliant futureapm4242 has a brilliant futureapm4242 has a brilliant futureapm4242 has a brilliant futureapm4242 has a brilliant futureapm4242 has a brilliant futureapm4242 has a brilliant futureapm4242 has a brilliant future
Re: problem with running labview simulator
I just got the same error. Did you ever resolve the issue?
Thanks
Unread 23-02-2016, 15:14
JeffB JeffB is offline
FRC #5052 (RoboLobos)
JeffB is a splendid one to beholdJeffB is a splendid one to beholdJeffB is a splendid one to beholdJeffB is a splendid one to beholdJeffB is a splendid one to beholdJeffB is a splendid one to beholdJeffB is a splendid one to behold
The simulation environment is a subset of all possible combinations. In the documentation, it lists all of the possible actuators/motors you can use. If you use something not on that list (because your robot is more complex than the sim), it'll throw this error.
