Go to Post We had an autonomous bug last year . . . Funnily enough, this worked real well and other teams were asking us for this "feature." - dragoonex [more]
Unread 06-02-2015, 17:21
ChrisTeam1289's Avatar
ChrisTeam1289 ChrisTeam1289 is offline
Mechanical Lead | Driver | #1289
AKA: Cristian W.
FRC #1289 (Gearheadz)
ChrisTeam1289 is an unknown quantity at this point
Exclamation Issues with SMC SS5Y3-41-06-N7T 6 Station Base Mount
Hey,
We are currently having issues with the SMC SS5Y3-41-06-N7T 6 Station Base Mount, we have the entire pneumatics system working, up until we connect tubing into the pressure port, and then we can't get any pressure readings, however if we remove the tubing from the port and cover the open end with our thumb we will get pressure readings, we are really stumped at the moment and could use some help.
Unread 06-02-2015, 17:27
Cecil's Avatar
Cecil Cecil is offline
AKA: Alex Hummel
FRC #2010 (Lightning Bots)
Cecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to behold
Re: Issues with SMC SS5Y3-41-06-N7T 6 Station Base Mount
What do you mean by pressure readings?
Did you remove the plug on the other side of the base station, put teflon tape on it and tighten it back in?
Do you have any unused spaces for solenoids? Do you have blank station kits installed over any port without a solenoid?
Do you have cylinders attached to both the input and output of all of your solenoids?
Did you install the gaskets below each solenoid and make sure they are tight on the base kit?
I'm right 90% of the time, so why worry about the other 3%?
Unread 06-02-2015, 18:50
Nate Laverdure's Avatar
FRC #2363
Originally Posted by ChrisTeam1289 View Post
...if we remove the tubing from the port and cover the open end with our thumb...
FYI:
A pressure of 7 bar [100 psi] is sufficient to penetrate the skin.
Please don't use your body as a troubleshooting tool.
