Go to Post They improvised. They overcame. They persevered. And they succeeded. ... I cannot remember being more proud of a group of students with which I have been associated. - dlavery [more]
Unread 06-02-2015, 19:53
cstelter cstelter is offline
Programming Mentor
AKA: Craig Stelter
FRC #3018 (Nordic Storm)
cstelter will become famous soon enough
Re: Slowing down the drive motors
Originally Posted by notmattlythgoe View Post
Originally Posted by GeeTwo View Post
A simple way to still allow full top speed but give fine control at low speeds is to square the magnitude. You'll get 1/4 speed at half throw on your joystick, and full speed at full throw:
myRobot.tankDrive(stick1.getY() * Math.abs(stick1.getY()),
stick2.getY() * Math.abs(stick2.getY());
Correct. Only if you don't want to limit your top speed.
Hmm. Unless I'm reading the RobotDrive code wrong:
public class RobotDrive implements MotorSafety {
    public void tankDrive(double leftValue, double rightValue, boolean squaredInputs) {
        if(!kTank_Reported) {
            UsageReporting.report(tResourceType.kResourceType_RobotDrive, getNumMotors(), tInstances.kRobotDrive_Tank);
            kTank_Reported = true;
        // square the inputs (while preserving the sign) to increase fine control while permitting full power
        leftValue = limit(leftValue);
        rightValue = limit(rightValue);
        if(squaredInputs) {
            if (leftValue >= 0.0) {
                leftValue = (leftValue * leftValue);
            } else {
                leftValue = -(leftValue * leftValue);
            if (rightValue >= 0.0) {
                rightValue = (rightValue * rightValue);
            } else {
                rightValue = -(rightValue * rightValue);
        setLeftRightMotorOutputs(leftValue, rightValue);
    public void tankDrive(double leftValue, double rightValue) {
        tankDrive(leftValue, rightValue, true);
It looks like tankDrive(double,double) squares the inputs by default. So doing what is suggested will ^4 the inputs. It will certainly have the advertised effect either way. But if your robot won't really move until you apply 0.4 for example, you have to get your joystick all the way out to ~0.8 before it moves.
The best plan is probably to do as Ether suggested and go piece-wise linear. Perhaps first find your sweet-spot for operating the robot (say 0.4-0.7) map your deadzone to ~10-20% less than the minimum power to drive your robot and then map 0.9 to be the maximum you want to drive and then map 1.0 to 1.0.
There are many ways to code an OI...
I'll mention that what our team sees as a way to not lose motor strength and yet drive very slowly is to use a feedback encoder system so you are asking the wheels to go 0.4 of their fastest rotation rather than 0.4 constant output voltage. This way a PID can apply full power to the wheels to get it going but quickly cut back power as you reach your requested rate. If you are moving very slowly and something gets in your way, you can apply the full power of your cims to overcome and if your wheels happen to slip the PID would likely compensate back down to the maximum power possible without overcoming friction.
