Go to Post At this point in build season, I'm thinking that whatever type we can get built and working is the best type, by far! - MrForbes [more]
Unread 06-02-2015, 20:03
youngpilot youngpilot is offline
AKA: Mary Luking
FRC #2640 (The Hotbotz)
youngpilot is an unknown quantity at this point
Labview Encoder Problem
Hello, we are having problems with our encoder for this year's robot program. We have a dashboard project set up to see values but there is no response for rate or distance. Any suggestions for what we should be doing to fix the issue we're having? Screenshots are included of our Begin and Periodic Tasks vi.
https://flic.kr/p/qN6jLP
https://flic.kr/p/r3fyYb
Unread 07-02-2015, 08:35
Re: Labview Encoder Problem
It looks like you copied the example, and then created constants for each of the Encoder Open inputs. But you left the constants disconnected, with the code still using the controls from the example. I can't tell what values you have set them to on the front panel.
You should probably just delete those controls and wire the constants in their place.
Your wiring in Periodic Tasks is confusing. I can't tell where things are going. It looks like some of the wires cross under the right side of a node in order to connect to a terminal on the left. And what's that feedback node doing there? You might get a more easily understood block diagram if you simply used the Clean Up tool on it.
Unread 07-02-2015, 09:01
Qbot2640's Avatar
Qbot2640 Qbot2640 is offline
AKA: Terry McHugh
FRC #2640 (Hotbotz)
Qbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond repute
Thanks for spotting this...we'll fix it today - be on the lookout for a follow-up.
(And sorry we posted this in the wrong forum...any way to move it to "Programming - Labview"?)
2012 Palmetto Regional Winners (Thanks 2059, 2815, and 287).
2012 Newton 14th Seed
2013 Chesapeake Regional Imagery Award Winners
2014 North Carolina Regional Imagery Award Winners
2014 Greater DC Regional Team Spirit Award Winners
2015 North Carolina Regional Finalists (Thanks 3971 and 587)
