Go to Post HOSE CUTTER: A tool used to make hoses too short. . - dlavery [more]
Unread 06-02-2015, 11:02
jls667 jls667 is offline
None #2579
jls667 is an unknown quantity at this point
Re: Mecanum drive cartesian problems
I am using the wpilib library and robotdrive. I believe that I have to reset the gyro and use getangle.
Unread 06-02-2015, 11:25
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
We got our Mecanum Drivetrain Code working in field coordinates in December; click for the code on github. This is based on cRIO, but shouldn't need too much tweaking. This is built on the command based robot model.
Unread 06-02-2015, 13:09
cstelter cstelter is offline
Programming Mentor
AKA: Craig Stelter
FRC #3018 (Nordic Storm)
cstelter will become famous soon enough
Out of curiosity, why do you drive at 70% joystick readings in cartesian mode but full power in Polar mode?
Is there a purpose to Polar/Cartesian switch? Isn't calling cartesian with gyro-angle==0 equivalent to to calling Polar? Perhaps it is meant to switch between field-centric and robot-centric?
Not sure the CommandBase class will work in this year's lib so it may not just be load/go. Also, I think atan2 is on Math now, not MathUtils because we have proper java this year, so those are the obvious tweaks I see that will be necessary
Unread 06-02-2015, 14:48
None #2579
I am having trouble finding the java code mentioned by GeeTwo.
Unread 06-02-2015, 15:39
Programming Mentor
AKA: Craig Stelter
Does this work better for you?
https://github.com/frc3946/MecanumDr...libj/templates
Unread 06-02-2015, 21:12
None #2579
Thank you. That helps.
