Go to Post if we aren't here for some wisdom...what are we here for? - Molten [more]
Unread 02-06-2015, 09:20 PM
Brindlefly's Avatar
Brindlefly Brindlefly is offline
AKA: Jake Kinsella
FRC #4761 (Robockets)
Brindlefly will become famous soon enough
Help! Why Can't I Read Gyro Values Over the I2C Interface!
We bought a MPU 6050 gyro/accelerometer from Sparkfun Electronics. The spec sheet says the I2C address is 0x68 and that the WhoAmI register is at adress 075. When we read from that address we get the expected output of 104 decimal (0x68). When we tried to read the gyro register, at 0x43 - 0x47, we only get zeros. When we try to read the temperature register, we also get zeros. Is there something we have to do to enable reporting of the values?
private I2C gyro = new I2C(I2C.Port.kOnboard, 0x68);
	protected void initialize () {
		gyro.write(0x6B, 0x80);
	protected void execute () {
		byte[] whoAmI = new byte[1];
		gyro.read(0x75, 1, whoAmI);
		System.out.println("WhoAmI: " + whoAmI[0]);
		for (int i = 0x43; i <= 0x47; i += 0x02) {
			byte[] angle = new byte[2];
			gyro.read(i, 2, angle);
			System.out.println(i + ": " + angle[0] + "" + angle[1]);
	protected boolean isFinished () {
		return false;
	protected void end () {
	protected void interrupted () {
		end();
Unread 02-06-2015, 09:38 PM
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
Re: Help! Why Can't I Read Gyro Values Over the I2C Interface!
Looking at this Arduino driver, I think you need to select a range for the gyro and possibly wake it from sleep. According to the register map, that means writing 0 (250 degrees/sec), 1 (500 degrees/sec), 2 (1000 degrees/sec) or 3 (2000 degrees/sec) to bits 3-4 of the GYRO_CONFIG register (0x1B). To wake it from sleep, write a 0 to bit 6 of the PWR_MGMT_1 register (0x6B). You also might want to change the clock source to one of the gyros to increase accuracy.
Unread 02-06-2015, 09:44 PM
Brindlefly's Avatar
AKA: Jake Kinsella
Thanks for your help. I will try tomorrow!
Unread 02-07-2015, 10:21 AM
Brindlefly's Avatar
AKA: Jake Kinsella
Ok, now I am getting an output from the gyro but it changes only when you turn it and then it goes back to zero when it stops turning.
		gyro.write(0x6B, 0x03); // Power
		gyro.write(0x1A, 0x1B); // Basic Config
		gyro.write(0x1B, 0x18); // Gyro Config
		byte[] angle = new byte[1];
		gyro.read(0x47, 2, angle);
		double rotation = (angle[1] << 8) | angle[0];
		System.out.println("Rotation: " + rotation);
		return false;
		end();
Unread 02-07-2015, 10:55 AM
Brindlefly's Avatar
AKA: Jake Kinsella
Ok now I am adding up the values from the gyro to get degrees, but when the robot turns in the positive direction the value shoots up to the thousands, and in the positive direction it goes to -3 max.
Unread 02-07-2015, 02:41 PM
Brindlefly's Avatar
AKA: Jake Kinsella
Ok I just figured it out. Here is the code for anyone who is interested.
private static double degrees = 0;
	private I2C gyro = RobotMap.gyro;
	public GyroSensor () {
		gyro.write(0x1A, 0x18); // Basic Config
		gyro.write(0x1B, 0x00); // Gyro Config
	public double getDegrees (double deltaTime) {
		gyro.read(0x47, 1, angle);
		double rotation = (angle[0] * deltaTime) * 2;
		degrees += rotation;
		return -degrees;
Unread 02-08-2015, 09:43 PM
EricS-Team180's Avatar
EricS-Team180 EricS-Team180 is offline
SPAM, the lunchmeat of superheroes!
AKA: Eric Schreffler
FRC #0180 (SPAM)
EricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond repute
Hey Thanks!
We were just looking for something like this <sweet>
Don't PANIC!
S. P. A. M.
Unread 03-20-2016, 01:01 AM
David Lame David Lame is offline
FRC #0247
David Lame is a jewel in the roughDavid Lame is a jewel in the roughDavid Lame is a jewel in the roughDavid Lame is a jewel in the rough
Bumping this year old thread to thank the authors. This came up on a google search, and it was part of what got me able to get my new mpu6050 working.
