Go to Post It's cool to see that Shaun White is an active team member (6th person from top left). That guy must be amazing, as he can win a gold medal in snowboarding while also being active on a FIRST Robotics team. - Andy Baker [more]
Unread 07-02-2015, 00:16
kjohnson's Avatar
kjohnson kjohnson is offline
Insert Clever Title Here
AKA: Kyle J.
FRC #1610 (BOT)
kjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond repute
Re: Unable to connect to Dlink
Mark beat me to it, but the Driver Station works on DHCP this year. You shoud set your IP address to obtain automatically. Turn your firewall off or ensure there is an exception for mDNS (See the RoboRIO Networking section of the Getting Started Guide that Mark linked to above). Use Command Prompt and ensure you can ping "roboRIO-4159.local", if not, you may be having a DNS issue.
You can also try connecting to the RoboRIO via USB and navigating to the web interface at 172.22.11.2. Ensure the RIO received a DHCP address from the DHCP range of the radio. If not, make sure you have programmed the D-Link with the 2015 version of the bridge programming utility.
