Go to Post This is one area where you want an old hand in the room to show you how to work on this thing. .... If you survive it, electricity hurts really bad. - ebarker [more]
Unread 07-02-2015, 10:32
jnicho15's Avatar
jnicho15 jnicho15 is offline
AKA: Dan
FRC #0548 (Robostangs)
Team Role: Electrical
jnicho15 is just really nicejnicho15 is just really nicejnicho15 is just really nicejnicho15 is just really nice
Field Dimensions
How far is the litter container from the alliance wall? I can't find it anywhere.
2014: MIHOW DCA, Finalist
2015: MISOU Finalist; MILIV DCA, Winner; MIBED Winner; MICMP Winner, Engineering Excellence
2016: MISOU KPCB Entrepreneurship Award; MILIV DCA; MICMP 16th Alliance- 8-F winner
Unread 07-02-2015, 11:17
GaryVoshol's Avatar
Cogito ergo arbitro
Re: Field Dimensions
It would be variable based on the size of the carpet.
2.2 ALLIANCE STATIONS
Red and Blue ALLIANCE STATIONS are located on each end of the FIELD, behind the ALLIANCE WALLS, and are bounded by the edges of the carpet, the ALLIANCE WALL, and White gaffers tape, which extends from the end of each GUARDRAIL to the edge of the carpet. The STARTING LINE is the width of the ALLIANCE STATION and is marked with 2 in. White gaffers tape that is 2 ft. 6 in. from the PLAYER STATIONS.
Each ALLIANCE STATION contains one (1) Bin which contains LITTER.
2.3.3 LITTER
Each LITTER is a solid core, green Pool Noodle, manufactured by Tundra (Part Number: SR20C). They are between 4 ft 7 in. and 4 ft. 11 in. in length and have an outside diameter of 2.6 in. Given that the manufacturing process for Pool Noodles is not tightly controlled and the Pool Noodles used and distributed for the 2015 season were made in different production runs, Teams should expect some variation in rigidity, length, diameter, and surface characteristics
Each ALLIANCE starts the MATCH with ten (10) LITTER, all of which are located in a white Bin. The LITTER is marked 1 in. from each end and in the middle with 2 in. “Red” and “Electric Blue” gaffers tape to match the ALLIANCE STATION in which it starts. The Bin is on the carpet and centered behind the middle PLAYER STATION such that back edge of the carpet is tangent to the Bin. The Bin is constructed from a US Plastics Tamco 30 Gallon Polyethylene Tank (Item #: 4031). It is 30.5 in. tall with a diameter of 17.75 in.
(emphasis mine)
(since 2004)
Unread 07-02-2015, 11:47
jnicho15's Avatar
AKA: Dan
What should it be usually?
Unread 07-02-2015, 12:01
Probably about what the Pedestal was last year. As I recall that was near the back edge of the carpet.
