Go to Post Win, Lose or Tie, but do it in a way that FIRSTers will be talking about for years to come! - Bill Moore [more]
Unread 07-02-2015, 09:59
Herbie_3633 Herbie_3633 is offline
FRC #3633
Herbie_3633 is infamous around these partsHerbie_3633 is infamous around these parts
Dart Potentiometer Wiring
My team just got a Dart Linear Actuator and sensor kit but be can't figure out the wiring for the potentiometer.
Unread 07-02-2015, 10:08
Re: Dart Potentiometer Wiring
The pot has three connectors that should be marked on the case as to what each is.
  • ground
  • signal
  • power
It connects to an Analog input on the roboRIO.
Unread 07-02-2015, 10:36
1 & 3 connected by a wavy line should be ground and power. The order only changes the direction of the pot.
So 1=ground & 3=power might mean that turning counter-clockwise increases the signal,
while 3=ground & 1=power would be the opposite and clockwise increases the signal.
2 should then be the signal.
Does the pot have a make/model #?
Unread 07-02-2015, 10:37
FRC #3633
The connections are labeled 1,2, and 3 and a wavy line connecting 1 and 3 but there is no clear indication of what is ground and power.
Unread 07-02-2015, 10:42
FRC #3633
The brand is Bourns the part number is 3590S-2-201L
Unread 07-02-2015, 10:49
So yea,
  • 2 = signal
  • 1 = ground
  • 3 = power
power on 1 would be CCW (counter-clockwise) increasing
power on 3 instead would be CW (clockwise) increasing
In the schematic, the signal contact slides from left to right when the pot shaft is rotated clockwise.
So if 1 is ground, the signal when close to ground will read 0 and will increase as it moves right (CW shaft rotation).
If 3 is the ground, the signal when close to power will read nominally 5v (~4.8) and decrease as it moves right (CW shaft rotation) and gets closer to the ground.
