Go to Post Dean looks rather debonaire in a tux. Like some sort of engineer super hero. The tuxedo is like his Clark Kent costume under which lies his amazing denim suit, to be whipped out at a moments notice in the face of uninspired youth and problems unconquered. - phrontist [more]
Unread 07-02-2015, 11:42
peronis peronis is offline
Team Leader
FRC #3950 (RoboGym)
peronis is on a distinguished road
Noise from VRM
Hi all,
We have a electrical noise coming from our VRM. The only component wired to it is the router.
We switched to another VRM we had, and the same problem exists. Is this a problem, or is it normal for the operation?
If it isn't normal, then I think it might be interference from our wire runs, since we have the wires from two motors and 3 solenoids all running in a bunch from one side of the robot to another. I hear it though even if the robot is disabled and no current is going through them. So, I ruled this out.
Thoughts or suggestions would be helpful.
Thank you
Unread 07-02-2015, 13:03
Re: Noise from VRM
What connections are you seeing this noise on? How are you detecting it?
Unread 07-02-2015, 20:50
ozrien's Avatar
ozrien ozrien is online now
Omar Zrien
AKA: Omar
Re: Noise from VRM
How exactly is the robot not functioning? Is the robot itself misbehaving?
Unread 07-02-2015, 21:03
crollison crollison is offline
AKA: Chris Rollison
FRC #4809 (Black Knight Robotics)
crollison is an unknown quantity at this point
Re: Noise from VRM
Have the same issue, it's a very high pitched electrical kind of sound. Unplug the router and it stops. Doesnt' seem to be effecting anything, but does bother me some.
Unread 07-02-2015, 21:06
ozrien's Avatar
Omar Zrien
AKA: Omar
Re: Noise from VRM
Hearing an audible whine is normal with the VRM. It's switching freq is near the audible range, and it's load dependent so removing the load will silence it.
Unread 07-02-2015, 21:07
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Re: Noise from VRM
Boost regulator? The old PDB used to whine. We always claimed we had a squirrel in the bot somewhere.
Unread 07-02-2015, 21:43
Team Leader
FRC #3950 (RoboGym)
Re: Noise from VRM
Thank you for the responses. Everything works fine on the bot. The noise is from the vrm itself. I was wondering if other teams had vrms without this happening?
Definitely the circuitry inside, just concerned about comms going down at some inopportune time, or the router not receiving a constant 5v
Unread 08-02-2015, 01:01
philso philso is offline
FRC #2587
Re: Noise from VRM
It seems from your posts that you are concerned about an audible noise coming from the VRM rather than electrical noise that you are measuring with some instrument like an oscilloscope. It also seems that you are not seeing any failure or mis-operation of any sort. If this is the case, ignore the audible noise. It is common for components in circuitry like the VRM to emit audible noise while operating correctly. The presence or absence of the audible noise is not a reflection on the reliability of the VRM.
